Like Tree31Likes
Old 04-30-2014, 10:08 AM   #2116
Mopar's Avatar
The only down side to Martin's app is that it costs $10 a year. But it does include a generic set up sheet so you can store your set ups on the site in either private or public fashion so can be shared. P.S. I'm bored right now cause my car will be delivered today (by 2pm?) and am just waiting.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 04-30-2014, 10:31 AM   #2117
Jakesterama's Avatar
Trader Rating: 64 (100%+)
Originally Posted by mes View Post
Thank you Torrance, and no problem, Jakesterama! The "2WD" must have hidden somewhere between that caged bullet connectors...
I've never had an HPI/HB car before, but the D413 may very well change that, although I am Yokomo fanboy and my driving style does not suit 4WD at all - I am not trigger happy enough!
haha! I like you mes! This is my first new HB car, and so far (building) I really like it!
Originally Posted by Speedychris22 View Post
I understand that part, What I wanted to know is the difference between
(1 DOt F/F 1 dot F/R ) and (2 dot F/F 2 dot F/R) They are both 10 degrees kick up.
Originally Posted by Mopar View Post
For the same angle of kick-up or anti-squat, a shorter or longer mount will allow you to change the roll center.
I was kind of bummed that the kit only included 2 sets of each dot, so you can't recreate 2dot/2dot 1dot/2dot setup Ty uses. I went 1 degree more and tried to keep the roll center about the same since I tend to like a little more kick up for smoothing jumping.
Originally Posted by erevo1*16 View Post
Anyone else get a pre-load spring collar that has a 'dimple' in it?
I used 1.3 pistions, with 35wt TLR oil both front and rear.
I ended up using 20k for the front, and 7k in the rear from Team Associated, and went with the stock 100k for the center.
Nice touch on the diagrams in the manual for all the links T.D! It was really easy to do compared to a few other kits I've built.
Mine were all a-ok, sorry yours had a little dimple! I went 1.5mm 35wt / 1.6mm 30wt and 10k/100k/3k as an amalgamation of Ty's OCRC setup, what Torrance has said, and what I found out with my ZX5 w/Durango gear diffs on local tracks. All suspension geometry is from Ty's OCRC setup, except for the kick-up.
I didn't think the manual did the best job at illustrating keeping the notch to one side or the other when building the links. The steering links have both notches pointed outwards, and the rear links have both notches pointed inward. I didn't really notice till I had built my first steering link, so on my car, all my notches are to the passenger (right) side, whereas traditionally you build with notches to the driver (left) side. Not really a big deal though, just have to remember to spin them backwards on my D413!
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 04-30-2014, 11:36 AM   #2118
Trader Rating: 49 (100%+)
I didn't think the manual did the best job at illustrating keeping the notch to one side or the other when building the links. The steering links have both notches pointed outwards, and the rear links have both notches pointed inward. I didn't really notice till I had built my first steering link, so on my car, all my notches are to the passenger (right) side, whereas traditionally you build with notches to the driver (left) side. Not really a big deal though, just have to remember to spin them backwards on my D413![/QUOTE]
I agree about the dot thing. Especially since you cant buy them anywhere right now. The OCRC setup that I used had 2k rear diff. This was from Ty's website. Also wished they included more alum washers. I agree also on the links but I made sure I did mine all the same so it would not be an issue. The stock kick up is 8 degrees and Ty's is 10 so I went right in the middle. Car looks great. Now I have to paint the body. Going for an F1 Look
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 04-30-2014, 11:38 AM   #2119
-I caught that too with the notch markings in the diagrams, but the "true size" and orientation of the rod ends were great. I only needed to measure once for each link! But, yeah, I made all my link's notch marks on the LEFT. so I don't need to remember; Remembering stuff is overrated.
The reason I posted about my 'dimple' wasn't to gripe~ I ain't mad about it. (kind of a bummer, but no biggie.) but if there are 15 guys who have the kit, and 6 of them have a dimple... HPI/HB and Torrance deserve to know so they can get the issue fixed.
You know, I looked at Ty's set-ups and I believe I've read the entire thread here now, and I've watched countless videos on youtube about set-up...
-I run a Mugen MBX-6eco, with the only changes from BOX STOCK being a 1up on rear spring rate, and went from their 400wt shock oil to 30wt losi. and added some droop, and added some protection (skids. and shock tower bra) and for the way I drive, it's fantastic.
That being said, I do NOT drive like Ty.... his set up help is appreciated, but; as much as I'd like to drive as FAST as Ty, that probably isn't going to happen, and even the track at OCRC
This is OCRC Right???
https://www.youtube.com/watch?v=Cp40GBVxE2I
Well, this is the track 'Surface' (not track)I'll be running on at my local outdoor here in MN, it has a 1/8 and a 1/10 track. (please be nice, it was half way through my first lap, on an all new layout, and the first time with a radio in my hand since September, since my 4 year old learned to ski this winter instead of snow bashing the RCs. *excuses are like a***oles, everybody has one*
https://www.youtube.com/watch?v=7tNLYdTy8qI
erevo1*16 is offline   Reply With Quote
Old 04-30-2014, 12:11 PM   #2120
Default orio or tekin esc?
hi guys still waiting on my kit from tower- says early may now, so there is some light at the end of the tunnel,lol. I was wondering if there is a difference between these two speed controls, or is it just user preference, any help and honest feedback would be much appreciated, still trying to sort my electronics out- but i am sticking with a 6.5 turn motor.
jdmjimmy is offline   Reply With Quote
Old 04-30-2014, 12:25 PM   #2121
Mine looks to be 'pre' anodizing...
I was trying to thread it on and I thought it felt a little harder to do than the other one (this one was #2 I grabbed in the Bag-A-Fronts.)
Not a huge deal by any means, but because of the flat spot, when I threaded it on, it took a lot of the black anodized covering off of the shock's thread peaks.
Just wanted to share to make you guys aware, to make sure it's a 1-in-a-howevermany... rather than each kit having one~
There are supposed to be FOUR dimples per collar. The reason for those is because i like to adjust my collars in 1/4 turn increments. This way they're easier to count and you can set left and right equally.
As far as the tightness they were intentional because some drivers like them tight but if you want to loosen the threading action you can cut a portion off the o-ring inside the collar (see build tip #3 on page 1).
Torrance Deguzman
HPI/HB Mechanical Engineer
powered by LRP
T. Deguzman is offline   Reply With Quote
Old 04-30-2014, 12:28 PM   #2122
Less dots = higher hinge pin (higher roll center)
More dots = lower hinge pin (lower roll center)
Torrance Deguzman
powered by LRP
Old 04-30-2014, 12:29 PM   #2123
FYI absolute hobbyz has thd kit instock
My Credit Card
Old 04-30-2014, 12:32 PM   #2124
you'd be surprised how Ty's setups are EASY to drive. his speed comes not from a nervous handling car but from its stability.
Torrance Deguzman
powered by LRP
Old 04-30-2014, 12:33 PM   #2125
Torrance, I think he is talking about the small manufacturing defect on the flat part where the spring would seat.
Hot Bodies D413 1/10 4WD Buggy-defect.png
practice_lap++;
Old 04-30-2014, 12:46 PM   #2126
oh that? these parts are spit from a CNC machine into a bucket then transported to the anodizer. sometimes some dings may happen. it's difficult to avoid. that seems pretty minor though. i doubt it'll affect the car's performance, and once the spring is on you won't even see it.
Torrance Deguzman
powered by LRP
Old 04-30-2014, 01:03 PM   #2127
Rybeau40's Avatar
Any idea how many they have on hand?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 04-30-2014, 02:24 PM   #2128
Jpm1's Avatar
My order with tower has changed to all back orders now early May, before today the parts were late April and only the kit early May, curious to know when the next shipment is in relation to their early May quote.....
Justin
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 04-30-2014, 03:47 PM   #2129
Matt :-)'s Avatar
I actually read the 1st page but did not see any info on this. Im not talking about the steering arm piece. Im talking about the metal mounts that hold the arm.
Oops, my bad.
Matt :-) is offline   Reply With Quote
Old 04-30-2014, 04:19 PM   #2130
Trader Rating: 44 (100%+)
Anyone finding wheels available anywhere?
Aaron Moore
Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
