Like Tree31Likes
Old 04-29-2014, 08:26 PM   #2101
mes
Originally Posted by T. Deguzman View Post
AE/Kyosho 2WD fronts will not work on the D413.
Originally Posted by Jakesterama View Post
Gotta be honest, I missed that you were asking about 2WD fonts, sorry about that
Thank you Torrance, and no problem, Jakesterama! The "2WD" must have hidden somewhere between that caged bullet connectors...
I've never had an HPI/HB car before, but the D413 may very well change that, although I am Yokomo fanboy and my driving style does not suit 4WD at all - I am not trigger happy enough!
mes is offline   Reply With Quote
Old 04-29-2014, 09:30 PM   #2102
JDJamminX1's Avatar
Originally Posted by JDJamminX1 View Post
Done.
Nope just a little dirt
LRP - MUGEN - AKA - OCRC - UPGRADE - SCHELLE - DE RACING
JDJamminX1 is offline   Reply With Quote
Old 04-29-2014, 10:58 PM   #2103
Trader Rating: 49 (100%+)
Received my kit today and started the build, the only stuff that I have to do is the shocks and electronic mouting. Quick question, are u guys puting loctite on the 3x20 that screw into the bulkhead?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 04-30-2014, 03:58 AM   #2104
mes
If it is a metal to metal connection, I'd always use loctite.
Old 04-30-2014, 04:39 AM   #2105
I have to say I'm very impressed with the build so far! Couple of small details I think we're left out from thd manual but other then that it's coming along great!
My Credit Card
Old 04-30-2014, 05:25 AM   #2106
Torrence can u explain the difference between the arm mounts
I'm using ty setup from OCRC which he used 2 dot f/f and 2dot f/r which gave 10 degrees kick up, if I used 1 dot f/f and f/r it would also give me 10 degrees. Is the a difference?
My Credit Card
Old 04-30-2014, 05:41 AM   #2107
Matt :-)'s Avatar
Check out the 1st post on this thread. It explains this in detail. Plus there are video links explaining design and set up options on the D413. It's really good stuff. You'll like it.
Matt :-) is offline   Reply With Quote
Old 04-30-2014, 06:39 AM   #2108
When building the car, dremel out a little of the chassis behind the front hinge pins where the nyloc nut is, it's just a little close to the chassis. In a heavy knock the nut can hit the chassis and that's the last part you want to damage and have to replace.
derekk is offline   Reply With Quote
Old 04-30-2014, 07:21 AM   #2109
I actually read the 1st page but did not see any info on this. Im not talking about the steering arm piece. Im talking about the metal mounts that hold the arm.
My Credit Card
Old 04-30-2014, 08:38 AM   #2110
Refer to the setup sheet in the manual. On the left side of sheet there are charts that show all the resulting kickup and antisquat angles from the possible dot combinations.
Torrance Deguzman
HPI/HB Mechanical Engineer
powered by LRP
T. Deguzman is offline   Reply With Quote
Old 04-30-2014, 08:53 AM   #2111
Anyone else get a pre-load spring collar that has a 'dimple' in it?
Mine looks to be 'pre' anodizing...
I was trying to thread it on and I thought it felt a little harder to do than the other one (this one was #2 I grabbed in the Bag-A-Fronts.)
Not a huge deal by any means, but because of the flat spot, when I threaded it on, it took a lot of the black anodized covering off of the shock's thread peaks.
Just wanted to share to make you guys aware, to make sure it's a 1-in-a-howevermany... rather than each kit having one~
I had a long night and got to Bag D, and sanded/sealed the edges~
I used 1.3 pistions, with 35wt TLR oil both front and rear.
I ended up using 20k for the front, and 7k in the rear from Team Associated, and went with the stock 100k for the center.
Nice touch on the diagrams in the manual for all the links T.D! It was really easy to do compared to a few other kits I've built.
erevo1*16 is offline   Reply With Quote
Old 04-30-2014, 09:30 AM   #2112
I understand that part, What I wanted to know is the difference between
(1 DOt F/F 1 dot F/R ) and (2 dot F/F 2 dot F/R) They are both 10 degrees kick up.
My Credit Card
Old 04-30-2014, 09:32 AM   #2113
Mopar's Avatar
For the same angle of kick-up or anti-squat, a shorter or longer mount will allow you to change the roll center.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 04-30-2014, 09:35 AM   #2114
Interesting so a smaller dot config is a lower roll center or higher?
Here's a quick pic
My Credit Card
Old 04-30-2014, 10:04 AM   #2115
Mopar's Avatar
Raising the lower pin mounts (less dots) would raise the roll center. This is the opposite of the upper links changes where if you raise the inner ball it will lower the roll center. And vise - versa to lower roll centers. This has been something I've had to relearn over the years. What helped me the most lately has been a smart phone app by Martin Crisp (aimed at sedan racing) but mirrors the Hudy set-up guide I have trusted for a long while. The only things the app or guide doesn't cover is jumping. All else is the same physics, including full scale cares.
