Like Tree31Likes
Old 04-26-2014, 11:53 PM   #2041
Trader Rating: 22 (100%+)
Originally Posted by Rybeau40 View Post
So i have his showing right now:
Receipt ID Date Time Status
************* 04/26/2014 12:25 PM IN PROCESS
No idea if that means I got one coming or not, but they did take my money.
Maybe it'll go out with mine on monday called customer service and for some reason it got held up, Looks like i'll probably be building my kit in a motel room next weekend....
noproblems209 is offline   Reply With Quote
Old 04-27-2014, 06:46 AM   #2042
Rybeau40's Avatar
Originally Posted by kdeleon View Post
Thanks guys for answering my late night inquiry. And my first time dealing with 100k diff oil and wow is that stuff thick.
What diff oils are you using brand wise? What setup you going with oils wise front, center, rear?
Btw, the three piece body
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 04-27-2014, 07:33 AM   #2043
ferrarieeeee's Avatar
Not sure if this has been asked b4... For diff maintenance it is easy/complicated? How many screws do I need to loose for taking the diffs out?
Electric: eb48.3 / eb48sl / 811e / d413 / b5 / b5m / kr / pro2b / msc / scte
Nitro: nb48.3 / xb8
ferrarieeeee is offline   Reply With Quote
Old 04-27-2014, 08:20 AM   #2044
Jakesterama's Avatar
Trader Rating: 65 (100%+)
Originally Posted by noproblems209 View Post
Bullet's are the way to go, just keep your wires short enough so they can't be plugged in backwards.
+1
Deans made sense when ESC's were prewired and you had to put some kind of connector on them. Now that you have to solder the wire on the ESC anyway, it just makes sense to remove the intermediate connector. One less point of increased resistance, and one less thing to fail. I like to put a piece of red electrical tape around the + socket on my batteries just as a sanity check.
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 04-27-2014, 08:43 AM   #2045
kdeleon's Avatar
I went with Torrance's original recommendation:
Front: TLR 15k
Center: Kyosho 100k (I guess I could have used the one in the box, but I already had this one)
Rear: TLR 3k
Hope that helps
kdeleon is offline   Reply With Quote
Old 04-27-2014, 09:14 AM   #2046
Bullet vs deans
a battery pack with wires coming out (direct wire) and deans offers the least internal risistance, lots of the onroad guys are changing to direct wire with deans, to get the max out of the battery
Caged bullets are crap and inconsistent connection, i ran really good caged bullets, and a couple of weeks i burnt my finger (it left a burn mark) as i pulled the caged bullet out of my battery so i changed out to solid bullets
4mm Solid bullets with a cross cut in them offers the best repeatable connection, i could see a huge difference in my scte 2.0 with 4000kv 550 motor, i got more punch, faster top end with solid bullets (team powers bullets), very noticeable, also before i changed bullets i would be putting in 5200-5500mah into my 7200mah 2S pack after a race...with the solid bullets that dropped to 4500-4800 mah...there must have been a lot of energy wasted in the caged bullet
i tried the same experiment in my TC6.1 in 17.5, and it made a noticeable difference for the better
bullets have higher internal resistance, than direct wire and deans connector
5mm bullets as offered in some pack also have higher resistance then the 4mm bullets
dont believe me ....go to SMC facebook page where Danny explains it all, backed up with actual measurements
Cygnus X is offline   Reply With Quote
Old 04-27-2014, 09:58 AM   #2047
murky123's Avatar
all done, and driving great !!
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 04-27-2014, 10:20 AM   #2048
Matt :-)'s Avatar
Thumbs up
DUDE !!! Your D413 looks AWESOME !!! Post some nude (body off) pictures of it !!!
Matt :-) is offline   Reply With Quote
Old 04-27-2014, 10:41 AM   #2049
murky123's Avatar
Old 04-27-2014, 10:42 AM   #2050
Originally Posted by Cygnus X View Post
Bullet vs deans
Just went and checked it out, and I appreciate his testing. The difference between his Genuine Deans (0.11 mOhm) and caged bullet (0.39 mOhm) is 0.00028 Ohms. On a 30 amp pull, this will result in a 0.0084 VDC difference between the 2 connections. Or less than 0.1% of the battery voltage. I understand looking for every 10th on the track, but I don't think that difference is going to be felt. Even if you are talking unloaded RPM (rating you stated for your motor was 4000kV) you are talking 33RPM. Once loaded, this difference is even smaller.
This is assuming that they have similar resistance in all the solder joints. I find bullets much easy to solder to. Deans can melt slightly and lose contact area as the angle of the metal in the plastic changes, and getting a nice (non cold solder joint) is much easier with a bullet. Using larger gauge wire is also much easier with a bullet.
The average brushless RC car is going to have over a foot of wire in it. In Danny's post he points out that 1 foot of 12AWG has 1.46 mOhm's of resistance, and 10AWG only has 0.76 mOhm. With this information, you would be much better off increasing your wire size by a couple of gauges, rather than trying to save a couple 10th's or 20th's of a milliohms in the connector.
I take a little issue with his test rig too. One side of his test leads is 4mm bullets of unknown origin and resistance. Then the clamp has a flat mouth, favoring any flat connector. When clamped to a round connector like a bullet, there is going to be vastly reduced contact patch between the clip and connector. Finally, when you are dealing with fractions of a milliohm, a thin layer of oil from your skin can make a difference. Were these connectors cleaned before testing? How old/how much oxidation has happened to metal?
practice_lap++;
Old 04-27-2014, 10:49 AM   #2051
Trader Rating: 49 (100%+)
With the wing sitting lower, will that give more downforce?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 04-27-2014, 10:49 AM   #2052
Matt :-)'s Avatar
Oooohh Yyyaaahh...
Old 04-27-2014, 10:53 AM   #2053
Matt :-)'s Avatar
I'm not sure. The car you're looking at belongs to murky123.
I could only guess it would be less down force, and maybe lower center of gravity.
Old 04-27-2014, 10:55 AM   #2054
Check the first post, there is a lot of info there
Originally Posted by T. Deguzman View Post
it's a built in feature - you can run the mounts in a high or low wing configuration. high wing is more stable on the ground. low wing is more stable in the air during high wind conditions. it was very windy at the worlds coupled with some big jumps.
practice_lap++;
Old 04-27-2014, 10:58 AM   #2055
fq06's Avatar
He also did mention it affects body roll. Makes sense with the ability to raise or lower the placement of the mount and wings weight.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
