Like Tree35Likes
Old 04-17-2014, 07:29 PM   #1846
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Pre-order placed.
Don't let me down HB!!! Hope this wheeler lives up to all it's expectations.
BOLISARIO is offline   Reply With Quote
Old 04-17-2014, 07:36 PM   #1847
Originally Posted by Cygnus X View Post
this is the toro ts120....and thats a metallic painted plastic case not aluminum
if theres another version out there for 120 bucks...is it really a deal ?
btw bluetooth at a crowded track looses range really quick....at home my little bluetooth speaker has a range of about 10m (30feet)...at the track...about 30cm /12"...but i do like the idea of bluetooth programming even if i do have to hold the phone super close to the car
The aluminum TS120 just came out I have the first in US. I am very familiar with the plastic case model. There is a wifi module coming soon which will greatly increase range
Beaker151 is offline   Reply With Quote
Old 04-17-2014, 08:05 PM   #1848
justpoet's Avatar
Trader Rating: 16 (100%+)
Where is the all metal available for purchase in the us? Bluetooth to my iPhone sounds great. I assume normal pairing and an app download is all that is required?
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 04-17-2014, 08:32 PM   #1849
Originally Posted by boudin4evr View Post
what were the part numbers for the AE xrings? Needed?
what about the kit springs? I see Ty uses Xgear springs
ill be on medium bite clay or medium bite outdoors
bottom skins for the CF chassis?
ae rings are sold out everywhere and backordered good luck on those or any ae part for the b5 or b5m lol
evolution03 is offline   Reply With Quote
Old 04-17-2014, 10:27 PM   #1850
is this what boudin4evr is lookn' for?
http://www.amain.com/product_info.ph...tion-X-Rings-8
RC Planet has em also
Eric Summers is offline   Reply With Quote
Old 04-17-2014, 11:21 PM   #1851
Trader Rating: 17 (100%+)
Bluetooth and 2.4ghz radio systems don't play so well together. Hopefully it can be turned off when you are actually driving the car.
AlderBoy is offline   Reply With Quote
Old 04-17-2014, 11:44 PM   #1852
justpoet's Avatar
As long as it requires pairing and is low power Bluetooth, there is very little chance it will interfere with the rx, and it wouldn't get reprogrammed due to the pairing requirement.
Old 04-18-2014, 04:57 AM   #1853
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
The ESC and the Bluetooth module work flawlessly I have been running the system for months with the toro ts120 plastic case . I am able to put the module in the car during practice and program the ESC from the driver stand when I want to make changes. These escs can be picked up at discountrcstore.com for $99
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 04-18-2014, 07:04 AM   #1854
lbenton's Avatar
Trader Rating: 48 (100%+)
Is what I am thinking right, that this should be filtering into US hands next week?
My pre-order is at a LHS so I do not expect to be the first one to get his. But I have this bag at home with tires / ESC / Motor / Receiver and a servo in it.
I have a feeling that if I am lucky I will have a week or two with it before my track turns into access road for the highway expansion.
lbenton is offline   Reply With Quote
Old 04-18-2014, 07:19 AM   #1855
well tower has the cars now, and is re-packaging the stuff, BUT Team drivers and stores have been able to pre-order for a long time(months), and orders go out in the order received...also people could preorder the buggies for a bout two weeks before it was visible on towers website....so there might be a lot in line to get this buggy even though you preordered the second it was visible online
i think it might actually be available in LHS first....we will see...
Cygnus X is offline   Reply With Quote
Old 04-18-2014, 07:43 AM   #1856
I would say very little chance you will notice, but it is RF and anything else on the same spectrum (2.4ghz) will cause some interference and take duty cycles away from its neighbors. There is a very good chance the ESC is smart enough to turn the Bluetooth way down or off once the car is moving.
Old 04-18-2014, 09:31 AM   #1857
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Torrance
can you explain the markins on the shock shafts as far as length in mm or build is concerned
first mark in length, 2nd mark, clush with shaft etc...
I dont see specifics on setup sheets
just shock lengths
thanks
the aluminum rear bulkhead on Tys car , im sure that is custom milled right?
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 04-18-2014, 10:00 AM   #1858
kdeleon's Avatar
Wait. Are you saying you know for a fact that Tower already has the cars or are you saying IF Tower had the car, it would still take a while for someone to potentially get it.
kdeleon is offline   Reply With Quote
Old 04-18-2014, 10:24 AM   #1859
Super Moderator
DRTMI's Avatar
Trader Rating: 27 (100%+)
Torrance
just shock lengths
thanks
The markings on the shock shafts are to use as measurements for droop.
A gun in the hand is better than a cop on the phone.
A 9mm might expand but a .45 will never shrink.
The gene pool needs a little chlorine.
DRTMI is offline   Reply With Quote
Old 04-18-2014, 11:55 AM   #1860
boudin4evr's Avatar
I know,
I was wanting to know the build lengths per mark
Marc Richard
