Like Tree42Likes
Old 04-13-2014, 04:30 PM   #1771
Trader Rating: 94 (100%+)
Originally Posted by murky123 View Post
you can use them 2 ways. its a tuning option. low or high
up sidw down?
redracerd is offline   Reply With Quote
Old 04-13-2014, 05:10 PM   #1772
Jakesterama's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Speedychris22 View Post
Murky how many blank pistons did u have in ur kit?
Check the first post - The kit comes with four sets of pistons, one set is blank, the other three are 4 hole: 1.2mm, 1.3mm, and 1.4mm. They are not tree-ed and are ready for use.
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 04-13-2014, 05:27 PM   #1773
Originally Posted by redracerd View Post
up sidw down?
Yep, with the mounts upside down it brings the wing further down. You can also add shims to increase or decrease the angle of attack.
"it's a built in feature - you can run the mounts in a high or low wing configuration. high wing is more stable on the ground. low wing is more stable in the air during high wind conditions. it was very windy at the worlds coupled with some big jumps."
"and.... each wing mount is held by an upper screw and a lower screw. you can adjust the wing angle by adding shims to one of the screw locations. you probably can't see it in the pictures by Ty has a 0.5mm shim on the lower screw to give the wing a little more angle of attack."
edit: added info from Torrance to first post
practice_lap++;
Old 04-13-2014, 05:52 PM   #1774
hairless_ape's Avatar
What's the internal transmission gear ratio? Trying to figure out what size pinions I'll need to have on hand.
hairless_ape is offline   Reply With Quote
Old 04-13-2014, 06:09 PM   #1775
Originally Posted by T. Deguzman View Post
currently the largest pinion that the car will accept is a 38T which will yield a final drive of 6.27. hopefully this can get you in the ballpark in the beginning. if a 4WD stock class does emerge then we'll make a smaller spur. for now however there hasn't been many tracks that run a 17.5 blinky 4WD.
(for reference the D413 comes with a 72T spur and the gearbox ratio is 43/13)
Looks like it is 43/13
practice_lap++;
Old 04-13-2014, 06:56 PM   #1776
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Damn I need to stop watching this thread, it makes me want to get a D413. It helps that Serpent or Tekno doesn't have a wheeler coming out in the near future.
BOLISARIO is offline   Reply With Quote
Old 04-13-2014, 07:17 PM   #1777
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
I can't find it right now but my favorite video is from the worlds. Cav spins in front of TY and they collide head on snapping the front of the B44.2 then TY is backwards and Mayfield head on with Ty and snaps the front off his B44.2. Ty drives away with a bent front sway bar.
Two of AE top drivers done in 1.5 second due to front arms breaking. Classic b44.2
Cameron Kellogg is offline   Reply With Quote
Old 04-13-2014, 09:45 PM   #1778
haha, there is good shot of it in this video at 6:15
+ YouTube Video
https://www.youtube.com/watch?v=FDi-5D0Wmn0#t=375
practice_lap++;
Old 04-13-2014, 09:51 PM   #1779
STLNLST's Avatar
Trader Rating: 21 (100%+)
My Yok has been bullet proof thus far but this car has my eyes wide open. I use to run HB sedans back in the day and this might be my first HB off road. Parts were always an issue even for us sponsored driver's. What's different this time around?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-13-2014, 11:43 PM   #1780
Default Parts availability
hoping they'll be all available once the car is hits the warehouse's amain hobbies has the parts available on the same day the buggy is due to arrive.
Rocktoy71 is offline   Reply With Quote
Old 04-14-2014, 12:07 AM   #1781
JS
JS's Avatar
Trader Rating: 70 (100%+)
Can anyone share any RTR weight for the D413 with a shorty?
JS is offline   Reply With Quote
Old 04-14-2014, 10:38 AM   #1782
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
You know you wanna
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 04-14-2014, 11:13 AM   #1783
I don't think I traded off any performance to gain durability. Definitely didn't sacrifice anything on suspension geometry or drivetrain. The one target I didn't quite hit was the minimum weight - the rules allow as low as 1613g but the D413 with a shorty weighs in around 1720g give or take. I tried to get it as close to minimum as I can but I would've had to skimp out on some strength to achieve it. Still though most of the competition weighs in close to 1800g and still has durability issues.
Added to the first post
practice_lap++;
Old 04-14-2014, 11:40 AM   #1784
boudin4evr's Avatar
Trader Rating: 18 (100%+)
man I am on the fence on this one!
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 04-14-2014, 01:15 PM   #1785
Don't take this the wrong way...
but what is there to be on the fence about?
you are really that worried about spare parts?
The only down side I've seen about this buggy is the shock caps have me a bit worried...
that and parts.
WAY more "Pros" than "Cons" in my eyes.
erevo1*16 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
SouthFloridaApp
