Like Tree35Likes
Old 03-26-2014, 03:14 PM   #1501
Jakesterama's Avatar
Trader Rating: 66 (100%+)
Originally Posted by T. Deguzman View Post
glad you brought that up! yes it seems the 22-4 fronts with the 12mm hex is compatible. I've tried a set of AKA evo wheels for the 22-4 and it fits. the offset is identical or nearly identical. the 22-4 front is probably the better option instead of the 22 front. at the time of my earlier post the 22-4 wasn't out yet.
as for a 4wd tire mounted on a 2wd rim, Ty has been running it like this, with PL 22 wheels and it's been fine.
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 03-26-2014, 03:40 PM   #1502
gticlay's Avatar
I totally missed that post. Will work well if/when I jump ship from the 22-4!
Just an FYI. The AKA rims for the 22-4 rub on my steering ballcups when I put them on the 22-4 unless I shave off most of the ballcup in that area. Something is not the same on the AKA evo rims - I think they have less offset than the TLR 22-4 rims do. Would be cool if Torrence could measure them as I don't have a tool that will work to measure the distance from the rim to the bottom of the hex.
gticlay is offline   Reply With Quote
Old 03-26-2014, 03:43 PM   #1503
Originally Posted by Jakesterama View Post
I pulled it from the links at the bottom of my post. Have you had a batch of production HB Springs to test yet? Any chance you could share your data from the Kyosho Springs and the HB Springs (and any others you might have) so we could compare apples to apples?
the HB spring rates are published. we'll have a sheet like the D812 springs which will list all of the info. as for the Kyosho springs... i wouldn't want to deny the Kyosho people from providing that info/service to their customers after all they charge big money for them. lol.
Torrance Deguzman
HPI/HB Mechanical Engineer
powered by LRP
T. Deguzman is offline   Reply With Quote
Old 03-26-2014, 03:49 PM   #1504
gticlay's Avatar
Have you tried the TLR Low Frequency springs or are they in the wrong range for your car?
Old 03-26-2014, 03:52 PM   #1505
looking at my car right now which has AKA evos mounted... no rubbing whatsoever with steering turned lock-to-lock and at full up and down travel. not sure about the non evo wheel though as i haven't tried them. if you look at the pictures closely the D413 has a specially shaped steering ballcup that provides clearance with the wheels.
Torrance Deguzman
powered by LRP
Old 03-26-2014, 03:59 PM   #1506
the front low freq range seem too soft, the rears seem ok.
the standard tlr springs cover the range but they have a huge step between springs!
Torrance Deguzman
powered by LRP
Old 03-26-2014, 04:00 PM   #1507
gticlay's Avatar
Yeah, the TLR guys had to go to the stiffer regular ones at the Cactus too.
Old 03-26-2014, 04:20 PM   #1508
Autocratic's Avatar
Trader Rating: 26 (100%+)
I believe Phend and Evans were running truck front springs at one point.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 03-26-2014, 04:56 PM   #1509
Pre order in. Super excited!!
Sct410, rc10b5, d413, Scx10 Honcho, Dex410v3, TRCE Slash, Hpi Blitz
Bluect9a is offline   Reply With Quote
Old 03-26-2014, 04:57 PM   #1510
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
as soon as amain has a pre-order, i'll be in with you!
RC*PHREAK is offline   Reply With Quote
Old 03-26-2014, 05:08 PM   #1511
gticlay's Avatar
He told me that he ended up with black standard for the race. Those guys are always trying new things...
Old 03-26-2014, 05:32 PM   #1512
TYTESSMANN's Avatar
Originally Posted by Grasschopper View Post
What lengths will be needed?
Originally Posted by GermanOffroader View Post
Hi too all,
this is my first post here.
I'm sorry for my english, but i hope everyone unterstand me.
My question is, whats the size of the thread of the turnbuckles?
3mm?
3,5mm? or
4mm?
And which company does produce titanium turnbuckles?
Or will there some produced by HB in the future?
Thanks an greetings
Martin
The sizes of the turnbuckles I use on the D413 are below
Front Camber Link 3 x 1 7/8
Rear Camber Link 3 x 1 3/8
Steering Link 3 x 1 1/4
I get my titanium turnbuckles from www.lunsfordracing.com they have great products.
Xray, RC America, Proline Racing, O.S. Engines, Orion, Hudy, MKS, A Main Hobbies, Muchmore, Avid, Lunsford, 110% Racing, MR33, Live RC, Red RC, www.tytessmann.com
TYTESSMANN is offline   Reply With Quote
Old 03-26-2014, 06:11 PM   #1513
kdeleon's Avatar
Ty, its good to see you post in the D413 thread. If you don't mind, I had another question. I looked at your setup sheets you posted on your site and it said you were posting race setups "as well as some basic starting point setups". I plan to use your Reedy setup for the indoor med to med high traction tracks in my area. But was wondering if you were going to post more generic setups that we could use for certain track conditions? Some of your other setups are a little more high bite then I would ever use.
kdeleon is offline   Reply With Quote
Old 03-26-2014, 08:40 PM   #1514
gticlay's Avatar
Yes, Lunsford is the best.
Old 03-28-2014, 10:27 AM   #1515
murky123's Avatar
I have bought the PL velocity front wheels (2735-02) and the TLR 22-4 front wheels (tlr43004) but there is a difference in offset. the TLR front wheels will make the car narrower in the front compared to the PL velocity wheels
both can be used, right ? any advantages when you make the front narrower ?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
kidcotton
