better springs (single rate) for powerstroke shocks >
Old 07-14-2013, 08:21 PM
Dave_S's Avatar
Default better springs (single rate) for powerstroke shocks
Can anybody recomend full size single rate springs for powerstrokes, I don't really see the need for dual rate and what just like to run a single rate. I am currently running red/red in front and yellow upper red lower in back.
Dave_S is offline
Old 07-15-2013, 02:25 PM
Dave_S's Avatar
No one knows about this? Or is it just something I should have found in a easy search
Dave_S is offline
Old 07-15-2013, 06:31 PM
that is really irritating when everybody ignores your post
Loast is offline
Old 07-15-2013, 07:00 PM
mxgregg's Avatar
Trader Rating: 32 (100%+)
I had power strokes and couldn't find a good replacement spring. Good luck with your search.
mxgregg is offline
Old 07-15-2013, 08:00 PM
I let my buddy with a slash and proline shocks use AE springs from my SC10 seemed to work just fine.
Cravin is offline
Old 07-16-2013, 12:00 AM
Dave_S's Avatar
I have the whole spring kit for 10.2 shocks, I was thinking about maybe trying then, but since they are a lot shorter the springs would have to thread down quite a bit, that would be ok with me, Just seems like there would be more preload, but I could be wrong.
Was also debating d8 shocks, but not sure if the springs would bind with my turnbuckles, its pretty close as it.
And the truck handles pretty good, but I would prefer single rate, so not sure what springs that would work. On front I am running primary yellow spring 7.3 lbs/in and red 8.1 lbs/in for the secondary. according to prolines this gives me a rate of 3.8 prime 8.1 seconadry
On the rear I have primary yellow 7.3 and secondary red 8.1
According to proline this gives me a rate 3.8 primary and 8.1 secondary
otal I guess I have 3.8prime spring and 8.1 for secondary rate Not sure what all that means, I mean I have an ideo, I have a roar car the I race, but any progressive rate springs I have had get tossed before they are even installed (cheap stuff anyways,
Thanks in advance for any guidance, I will appreciate any help I can get.
Also at this point should I just through d8's or another big bore that someone might recomend
Dave_S is offline
Old 07-16-2013, 07:38 AM
kcooper273's Avatar
Trader Rating: 62 (100%+)
I run the the rear spring on the front shocks and I turn the shock collar down until I can use only the single spring on the rear. They Proline Springs will work just fine.
Also check out M2C racing, they have a tapered 5 hole piston for the Powerstroke shocks, they work awesome.
kcooper273 is offline
Old 05-09-2015, 06:02 PM
wainwrightdw's Avatar
I am going to try the pro spec springs on the power stroke shocks
wainwrightdw is offline
