NeverWet! This stuff is a game changer!
I bought a bottle of this to try on my RC, decased and sprayed my servo, receiver, and esc. Then I sprayed my battery, motor and the whole damn car even the tires. Words can't describe how good this stuff really works and I would highly recommend this product for all your water proofing needs. I had my mini 8ight fully submerged in a ditch and was driving under water until the battery was almost at LVC, just to prove a point to some fellow racers. Amazing is all I can say.
Note...After I decased my elecs and sprayed them I did put the cases back on and ran it like I normally would.
Here's a video of the product and a link the the website.
Video...
http://www.google.com/url?sa=t&rct=j...48705608,d.aWc
Website...
I would also like to mention that this product makes removing dirt of your vehicle, as if your vehicle was dipped in teflon. Truly an amazing product and after you try it, you'll never use anything else for sure, no doubt, hands down, the end!
Video...
Website...
Yeah I'm not sure as to how to remove it, have not found that info out yet. It does leave a white haze on black surfaces, but it's not that bad and you can wipe 90% of that off after it dries which it dries fast. I still want to do more testing, but so far it works really well. I took one of my rtr receivers and put it into a cup of water for two weeks fully submerged, and to my surprise it worked flawlessly after taking it out and turning it on and using for three battery packs.
Where did you buy it from? Did I miss something on the Web site. So you need to make sure everything is cleaned prior like using a decreaser like simple green. I want to try while using on the whole car and lids . Can you post pictures for your thx
Stuff looks usable on so many things, will have to go out and pick some up. Thanks for the posting!
Stuff is quite amazing.
