tekin gen2 setup for a 2wd.
Hi.
im kinda confused with all the programming options in the hotwire and i thought maybe someone can share his settings.
my motor is a 8.5t gen2 in my b4.2.
i ran in a large outdoor track.
and im just a beginner in 1/10 and 2wd.
ho, and is there a feature that effects the throttle smoothness?
Best advice I can give since you are running an experienced motor with no experience is leave the esc box stock, and adjust your epa on the transmitter, then as you get it back to 100% I would start trying to adjust the esc.
Also there is a manual in the package and online that explains what everything does and how to adjust. If you have the hotwire and it is hooked up to the computer, you can hover over the adjustment needs or right click them and it will give you a little description on how to adjust and what it does.
While these are gen1 esc setups, they work well in gen2 equipment also:
http://www.teamtekin.com/hotwire/ESC...up-sheets.html
Throttle smoothness can be adjusted with Throttle Minimum, current limiter, and the epa's on your radio.
