XRAY XB9E Official Thread - they did it :)
#1306
Nice buggy
#1308
Hi, yes it's a bit confusing the XB8E is the newer model. It has been released this year and is a replacement of the XB9E.
The differences is that the front end of the XB8E is more agressive, it provides a sharper steering and faster response. The XB9E is more planted feeling, more forgiving also.
I'm leaning toward the XB9E just to have a less aggressive setup, that seems to suit me better for my driving preference.
#1309
Thanks for the clarification... if I were to buy a used XB9E... what are some common breaks that I might expect to see... and would any of those parts be compatible with the XB8E?
diff drive cups
diff housing and internals
complete center diff
center diff mount
lower hinge pins
side guards
drive shafts
rear chassis brace
servo mount
battery tray
motor mount
front bumper
wheel hexes/pins
wing mount
wing
things like that.. but chassis, arms, front rear diff ring and pinion are different sizes towers, shocks, all different..
#1310
Thanks Daniel... if I go with a XB8E... is the caster fully customized by tuning the front pivot balls? I wouldn't mind getting the XB8E if I can make it equally as stable to drive as the XB9E. It seems like the XB8E has more tuning options without having to buy extra parts, or am I mistaken?
Do you have a setup sheet available for your XB8E? I really liked the way it handled at 439 when you let me test drive it once a while back.
#1311
Correct. I worked setup on the xb9 for as long as I owned it to get it how I looked it... The xb8 started good.. Small tweaks and its money.
Your more than welcome to get my setup from me.. In don't have it on the website.. As I haven't changed much.. When u get it done.. Bring it by.. We will put it on the setup station. Get it all good to go.. If I get to the track early enough.. We can run some packs.. And tune it for ya.
#1318
xb8e chassis
I can't help but notice the similarity in the chassis layouts between the xb9e and xb8e. Does anyone know if I could run the the xb8e chassis on my xb9e with little to no modification?
#1320
