Loosing ride height.
What lol, I'm not understanding the question lol, I mean no traction on the rear!?
Suspended
Also building a shock with rebound is not right. You want the shock to be as "dead" as possible. The threaded preload collars are how you set ride height.
To be fair what you meant to say was losing ride height. Loose is the opposite of tight. As in if you don't know the difference between lose and loose, you may have a screw loose in your head.
+ YouTube Video | |
Typing from a phone doesn't always work out to well. I know how to set my ride height. When you run rebound, it will affect your ride height if you loose your rebound.
you should tell drake he's been doing it wrong this whole time:
+ YouTube Video | |
For example, if you have a very progressive spring, but static damping, the ratio between your spring rate and damping changes as the shock compresses... so all the way compressed you might end up with an under-damped shock.
And to the OP, sometimes you can lose ride height due to spring fatigue. I am not sure if that is the case with your situation, but I know when I ran my durango dex210, the durango springs were just aweful, and suffered from massive spring fatigue. Every single run the car would come off the track 1mm lower. After a day of racing, my collars would be 5 or 10 turns lower than at the beginning of the day. Changed to a different spring brand, and never saw the issue again. For example, the X-grear springs on my Kyosho... I can run the car for a month straight and ride height wont change at all.
spring fatigue and getting flat spots on your tires are the #1 and #2 reason to always store your car on a stand.
on 1/10th scale typically you run 0 rebound, it's really only used in 1/8th scale. there are some exceptions, but very few.
1/10th scale shocks are notorious for sucking in air, leaking, etc. it all depends on brand, maintenance, etc.
Don't sweat ride height change to much, it's natural that it will happen. Just check your ride height often. I check that and camber before every qualifier and main on raceday.
