    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 04-02-2015, 11:11 AM   #1381
Trader Rating: 138 (100%+)
Originally Posted by todb View Post
how will my slipper affect the steering? Also I have the different colored slipper pads that i can try as well. On the set up sheets I see the slipper listed as seperates and direct. what does that mean and how do how i use it to tune the car?
It won't effect steering, but the gears for the diff are plastic. Run too tight of a slipper and you'll be changing gears out a lot. Ask xb4 owners. Hopefully Kyosho will come out with steel crown and pinion gears. I bet that by the time they finish up the center gear diff they will move all gears to steel.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 04-02-2015, 11:34 AM   #1382
UMW708 is a sway bar kit for the RB6. I used the bulkhead on my RB6 and everything else on my ZX6. The sway bars are to long so you need to trim there length.
potatobed409 is offline   Reply With Quote
Old 04-02-2015, 02:03 PM   #1383
Thanks for that.
Old 04-02-2015, 03:40 PM   #1384
todb's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to todb
Good thing is that the 1.4 sway bar is included in the kit. copy paste from Amain.
•KYOUM724B Kyosho Rear Bulk Head w/Sway Bar Mount (Mid Motor)
•KYOUMW708-01 Kyosho Stabilizer Link Set (Mid Motor)
•KYOUMW708-11 Kyosho 1.1 Stabilizer Bar (Pink) (Mid Motor)
•KYOUMW708-12 Kyosho 1.2 Stabilizer Bar (Red) (Mid Motor)
•KYOUMW708-13 Kyosho 1.3 Stabilizer Bar (Orange) (Mid Motor)
•KYOUMW708-14 Kyosho 1.4 Stabilizer Bar (Yellow) (Mid Motor)
OVA Neo. HW, Motiv.
Orange is faster.
todb is online now   Reply With Quote
Old 04-03-2015, 02:16 PM   #1385
Texas Racer's Avatar
Default sway bar kit
Is there a difference between the RB6 and the ZX6 sway bars?
Texas Racer is offline   Reply With Quote
Old 04-03-2015, 03:24 PM   #1386
todb's Avatar
Hopefully i will know today.
OVA Neo. HW, Motiv.
Orange is faster.
Old 04-03-2015, 04:02 PM   #1387
Originally Posted by Kraig View Post
Where did it push, going in, middle, out? To me, when you tightened the front diff it would make it push more going into the turn but when you removed the front bar that balanced out the change to the diff.
I am still running the kits pistons, springs, and bar but a hole at 18mm for the lower shock mount. Mine would push going in and in the middle of the turn. However, my front diff nut must be going bad because now that became a little loose and my car is better, not great but better. The shock lengths are what he has listed on his sheet.
If you get bored sometime and want to try something different give Chris Nelson's setup a try. It is pretty darn good around these parts.
Setup was relatively on point. Had to keep the same shock package on the rear or the car would be loose. Other then that, the best so far. Can drive it super hard, and not far off track record for wheeler. Love this car....
Old 04-03-2015, 05:43 PM   #1388
Is there another option to use for the shock ends that won't collapse so easily?
Old 04-03-2015, 07:08 PM   #1389
todb's Avatar
The rb6 swaybars longer and have a slightly different bend. The bend is a little flatter but i think they can still used if they are trimmed to fit.
OVA Neo. HW, Motiv.
Orange is faster.
Old 04-04-2015, 08:57 AM   #1390
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Since we have been going back and forth which one did you end up with?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-05-2015, 05:45 PM   #1391
Kept the electronics as Tebo has them, and his CRCR shock package. Took it go SRS yesterday and it was stuck to the track like glue. Gear diffs are built but not installed as of yet.
Old 04-06-2015, 05:52 AM   #1392
Trader Rating: 50 (100%+)
I have been running Tebo's Reedy Race setup, with a longer rear link. Car is hooked up pretty good. I ran my ball diffs somewhat loose but i actually tightened them down to like a md tight feel and the car drove a lot better. I tried the gear diffs but feel the ball diffs just feel better.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 04-06-2015, 09:59 AM   #1393
I'm beginning to feel the same way. Run the bLl diffs til fried before switching. I have a pretty good knowledge of how to tune gear diffs to exactly what I want to the car to do, so it shouldn't be that traumatic to switch how are you liking the 4PX? I had the PKSR but it went up in smoke when the rechargeable battery freaked out.
Old 04-06-2015, 10:57 AM   #1394
Love it. came from a 4pks. the cheaper receivers is what sold me.
My Credit Card
Old 04-06-2015, 11:19 AM   #1395
Trader Rating: 20 (100%+)
Thumbs up
just have a quick question about toe been running the car for a couple of weeks and its really good! just confused a little bit on how to get a little more toe in the rear i was looking at the toe chart and to me using the EE bushings will give me 3.5 degrees of toe just want to make sure I'm looking at it correctly before i go ahead and put them on
thanks
toyota 2jz is offline   Reply With Quote
