    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree9Likes
Old 03-26-2015, 01:36 PM   #1351
Default My ZX6
Hi
This is my ZX6 purchased as roller and added electrics.
I wanted to wire up the ESC as close to motor as possible, try to keep balance optimal and using pics as reference from this thread and on internet.
It still has not been run yet but ready. Hope to go to a track tonight.
ZX6 with some carbon bits
V2 hubs
Lunsford turnbuckles and ball studs (so much easier after installed to use)
Tekin RXS
Tekin 7.5
Savox Servo
Reedy Shorty 4100mh 60c
The car was missing servo horn so i had to hack savox head to fit, i didnt like the servo on other side so i moved it using steering turnbuckle heads to lengthen to fit.
I hope to fine tune steering over time.
I have been out of RC buggies for almost 20 yrs big learning curve so far.
Dmitri Tech is offline   Reply With Quote
Old 03-27-2015, 06:47 AM   #1352
BigPinion's Avatar
Trader Rating: 19 (100%+)
Originally Posted by toyota 2jz View Post
i haven't been on this site for a long time and just purchased a zx6 the car went together really really well with tons of configuration setups just was wondering how this kit runs right out of the box currently the electronic setup is as follows
motor back on left side
servo infront of motor
speedo/receiver/shorty all on right side of car
car seems very balanced and am going on tue to test it out
just would like some opinions on how the car handles
track had ridiculous traction and am using slicks
med size track with a few nice jumps
thanks
Well.... Kit setup on high grip feels edgy and nervous, it actually scared the crap out of me the first time I drove it, way too aggressive. I have settled on Tebo's latest setup and now the car is a blast to drive. Once the car is calmed down a bit it is much easier to drive hard.
here's a link to the setup. You pretty much have to tear the whole car down but it is well worth it.
https://jtprc.files.wordpress.com/20...2015-crcrc.pdf
Pro-Line Racing Team Driver / Diehard-RC / XRAY
XRAY XB-2c '17 / XB4 '17
Diehard RC indoor Carpet Off-Road www.facebook.com/DieHardRC
BigPinion is offline   Reply With Quote
Old 03-29-2015, 03:24 AM   #1353
So would you suggest this Setup for highgrip ? Even the Motor Position? because it says wet in this sheet i don`t know if this is going to make any difference so far?
Or what "Lineup" would you suggest?
Ice22 is offline   Reply With Quote
Old 03-29-2015, 08:12 AM   #1354
BigPinion's Avatar
from my experience this setup is good for high grip as long as it is indoor clay. This setup worked well for me when many buggies were running slicks.
Old 03-29-2015, 09:46 AM   #1355
Thanks for your Response.
Andy ideas which Setup to use on high grip outdoor astroturf?
Old 03-29-2015, 09:50 AM   #1356
BigPinion's Avatar
There is some good info here
http:// http://www.petitrc.com/setup/kyosho/SetupSheetsKyoshoLazerZX6.html
Old 03-29-2015, 11:01 AM   #1357
thanks
Old 03-29-2015, 07:02 PM   #1358
When are we gonna see some aluminum upgrades for this buggy??? Bell cranks, caster blocks and center support would be nice from Kyosho or anybody!!!
potatobed409 is offline   Reply With Quote
Old 03-29-2015, 07:06 PM   #1359
Trader Rating: 139 (100%+)
Local LHS is out of kyosho pistons. What other brand works for the short term?
TLR 22T 3.0 (Retired), XRAY XB4 '18, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 03-30-2015, 09:02 AM   #1360
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Associated or Losi will work. Sometimes the piston isn't as thick so you might have to add a very thin washer to take up some play.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-30-2015, 01:50 PM   #1361
Gotcha. What size shim?
Old 03-30-2015, 03:23 PM   #1362
Super Moderator
Kraig's Avatar
Something like this if I remember correctly.
Old 03-31-2015, 07:49 AM   #1363
Gotcha. Will order today. Gear diffs will drop this afternoon. Coming from a B44.3, think I will try 7 up front, 5 in the rear. If it feels to stuck will drop rear to 3k. Track was recently rebuilt so slicks are the only things hooking up right now.
Old 03-31-2015, 08:20 AM   #1364
Does anyone know all the parts you need for the rb6 mod for the rear of the zx6.
gearit is offline   Reply With Quote
Old 03-31-2015, 12:26 PM   #1365
Super Moderator
Kraig's Avatar
Are you asking what is needed to run the rb6 arms on the rear of the zx6?
If yes,
UM713 or UM713B (3 hole arm)
UM561 Outer rear hingepin
UM603 rear hub spacers, aka drive washer set
I think that is is. You might not need the UM603 hub spacers but I thought I would mention it.
