    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 02-12-2015, 07:36 AM   #1306
carbons2k's Avatar
Trader Rating: 21 (92%+)
I think Im gonna try his full Reedy race setup minus the drilled rear arms.
question- what does lower fron suspension holder .5 mean? Is there a 1/2mm spacer under the front pivot blocks?
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 02-12-2015, 08:41 AM   #1307
Trader Rating: 48 (100%+)
Yes, Tom. I was running the Jconcepts invite setup last week at Wolcott but felt the car was a little loose on power. I'm putting on the Reedy race setup as well.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 02-12-2015, 09:17 AM   #1308
carbons2k's Avatar
Which car was you? Did you have the bodies with the candy red in the back? maybe some blue up front if I remember and some stars?
Tom Licata
Old 02-12-2015, 09:45 AM   #1309
yes, thats me.
My Credit Card
Old 02-12-2015, 10:16 AM   #1310
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Rather than just swapping out setups why not tweak the one on the car?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-13-2015, 02:57 AM   #1311
hacker's Avatar
Trader Rating: 140 (100%+)
Default non cab forward body
I am not a fan of cab forward bodies, they just look plain ugly imho.
Does anyone know if the zx5 'shoot' body fits?
or any other normal looking body.......?
hacker is offline   Reply With Quote
Old 02-16-2015, 03:47 AM   #1312
goBezerk's Avatar
Send a message via Skype™ to goBezerk
Yes it does hacker, I used to run my one on mine until I got the ZX6 one painted up.
► Paul Sims - KRCORCC - BRCCC - TFTR
► R/C racin', 1 percent car, 99 percent driver
► BEZERK RC on Facebook, PayPal accepted
► PROLINE - TEAM AE - GFORCE - R/C Race Supplies
goBezerk is offline   Reply With Quote
Old 03-01-2015, 02:34 PM   #1313
Texas Racer's Avatar
Default Shock pistons
what is the original size of shock pistons that comes with the kit?
Texas Racer is offline   Reply With Quote
Old 03-01-2015, 02:39 PM   #1314
jwcobra03's Avatar
Trader Rating: 69 (100%+)
1.6 two hole front and rear.
Kyosho TKI3/BCE/ XZB Speed
Kyosho TKI3-E/Tekin 1900
Kyosho RB6/Orion R10 Pro-VST 7.5
Kyosho ZX6/Orion R10 Pro-VST 6.5
jwcobra03 is offline   Reply With Quote
Old 03-01-2015, 03:10 PM   #1315
Thanks jwcobra03
Old 03-02-2015, 01:03 AM   #1316
Location: South Coast RC Ministry of Propaganda, Dorset, England
Another thing about the stock body, it has a massive hole at the back which looks like it was put there so that when a person who doesn't live in SoCal races in the winter, they destroy their electrics
I used an LAB03 Vulcan shell which is designed for the ZX-5 SP2008, by cutting it to shape before painting and gluing a few small pieces of foam here and there it can be made to almost completely enclose the car
HOTSHOT III is offline   Reply With Quote
Old 03-02-2015, 05:25 AM   #1317
tef
yes, thats me.
Ill be at wolcott on March 8th, it will be good to see other zx6s go on that track, havent been there in iver a year.
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 03-02-2015, 07:27 AM   #1318
any word on a center gear diff for this car? I currently run a HBD413 but love the way this car looks. I run a RB6 for my 2wd.
CaseyD is offline   Reply With Quote
Old 03-02-2015, 10:43 AM   #1319
Originally Posted by HOTSHOT III View Post
Not sure about a centre diff but just like the later ZX5s, the ZX6 has a pin in the front slipper outdrive which when removed allows the front and rear of the drivetrain to slip independently.
On the day the above pic was taken I took the pin out after round 1 which made the car a lot easier to drive in the slimy conditions and I ended up winning the A Main
Also if you get the ZX6 it's surprising how many RB6 parts are common such as diff internals, wheels, ball ends etc. which makes stockpiling spares a lot easier (I run an RB6 as well).
Old 03-02-2015, 01:01 PM   #1320
Ok. Good to know thanks. I really like my HB but have been drawn to the zx6 ever since it came out. Tough choice.
