    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 02-10-2015, 02:19 PM   #1291
cnelson3's Avatar
Trader Rating: 65 (100%+)
Originally Posted by K_King View Post
I run the 2x1.7s. I am really happy with my car right now. It's almost too easy to drive.
Did you drill out a set of your own? I have a set that used to be 1.6's that I drilled out to 1.7's.
cnelson3 is offline   Reply With Quote
Old 02-10-2015, 02:33 PM   #1292
Default Recent Reviews
Hey Guys! I was wondering if there are any recent reviews on the zx6. I'm in the market for a 1/10 4wd buggy and so far my choices are the Kyosho zx6, HB D413, and Xray XB4 4wd 2015. I'm close to completely crossing Xray off my list due to the lack of parts support here in the US, the cost of replacement parts (2 x Kyosho), and the lack of off road racing pedigree. Can anyone compare these three buggies? What do you consider the pros and cons of the the zx6?
logiqal is offline   Reply With Quote
Old 02-10-2015, 02:38 PM   #1293
Tony Marks's Avatar
Originally Posted by ColourGhost View Post
Hi Kyosho dudes.
I run the hb d413 and i'm a little tired of the shocks. I go Emulsion, and they build up rebound (suck in air) extremely fast. I use the kyosho x-rings and green slime and all, but after 2 batteries they have 100 % rebound (starting from zero).
I know the Kyosho's are silky smooth, so do you also have to let out air every 2 batteries to have them all "dead" (zero rebound) ?
If built right, they will last forever.
Team Kyosho America - VP Powermaster
JConcepts - 92zero Designs
Full Throttle/510 Raceway
Jared Tebo Products
Tony Marks is offline   Reply With Quote
Old 02-10-2015, 05:25 PM   #1294
Are you running the 2x1.7s all around? What oils are you running?
Hollywood_26 is offline   Reply With Quote
Old 02-10-2015, 07:25 PM   #1295
Trader Rating: 21 (100%+)
ok, so I'm setting up my buggy with the BB shocks and I'm wondering if you guys have tried other springs such as Losi, AE, Avid etc and are they the same length as the stock Kyosho springs? currently I only have AE, but for some reason, I can't get my ride height correct. I run out of threads on top of the shock body. I'm using AE springs of similar rate to Kyosho gold springs. any insight would be greatly appreciated.
joel45acp is offline   Reply With Quote
Old 02-10-2015, 08:25 PM   #1296
Brian C.'s Avatar
If you can't make ride height, then the spring is probably too short...
Brian C. is online now   Reply With Quote
Old 02-10-2015, 09:26 PM   #1297
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
https://dl.dropboxusercontent.com/u/...Feb%202015.pdf
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-11-2015, 07:23 AM   #1298
Thanks Kevin!
Old 02-11-2015, 07:30 AM   #1299
skeasor's Avatar
I think parts support for all of the higher end 4wd buggy's is lacking. You may as well take the D413 off of your list too if you're looking at parts support....Or just wait until the parts are back in stock and order as many as humanly possible
Support: http://bumpsandjumpsrc.com/, http://thehiddenhangar.com/, https://www.kranzelshobbies.com/, http://aerotechhobbies.net/
skeasor is offline   Reply With Quote
Old 02-11-2015, 08:12 AM   #1300
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I cannot comment on the other cars since I have only driven the zx6. Thinking back on what I have purchased I don't think I have purchased any must have items to make it more durable. Instead, I purchased extra items for tuning such as springs and sway bars.
You will always get people that say buy the usual stuff, arms, caster blocks, knuckles, rear hubs, etc. But if you are lucky enough to have a store which has a track look at the spare parts hanging on the walls. Then you can decide if you need to buy all of that extra stuff to carry around with you.
As for how the car drives, well I believe any car that is setup for your driving style will be good for you. Right now I like how my car drives.
I started out many years ago racing foam tires on carpet so I like cars with plenty of steering and I have that with my car. I could probably get that with the other cars you mentioned but I am not going to buy them and try and do that. I feel, for the price I paid for my cars to be worth it and any failures that I have are because of my lack of abilities.
Sorry I couldn't be of much help but maybe someone will get some information out of my soapbox rant.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-11-2015, 05:58 PM   #1301
ColbyRichards's Avatar
Shameless link to my for sale thread
Kyosho ZX6 roller + Team Orion 5.5 VST2 PRO
Retired
ColbyRichards is offline   Reply With Quote
Old 02-11-2015, 07:23 PM   #1302
Thanks for your feedback. I was able to find parts online for the zx6 without an issue. Im leaning towards kyosho.
Old 02-11-2015, 07:26 PM   #1303
I appreciate your feedback. I currently have an rb6 and that also has plenty of steering.
Old 02-12-2015, 07:09 AM   #1304
carbons2k's Avatar
Trader Rating: 21 (92%+)
Ok so Ive had my ZX6 for a few weeks now and Ive tried a few different things and Im debating going back to the kit setup again but basically the car is very 'floaty'. That's the best way I can describe it really. Having just coming from the 22-4 I felt that car was very forgiving to drive and very planted where my zx6 is very edgy and active. The surface I race on is a medium to high traction and its wet. Low pin M4 or m4 slicks.
What would adding more rear toe to? My toe block inserts are stock right now (D in D out) What about B in F out?
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 02-12-2015, 07:21 AM   #1305
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
I would try Tebo's CRCRC Setup and and go with his shock setup from the Reedy Race.
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
