    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 01-26-2015, 04:58 PM   #1261
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
How is the durability on the ZX-6?
pink_sleeve is offline   Reply With Quote
Old 01-26-2015, 05:21 PM   #1262
Potoczak's Avatar
Trader Rating: 111 (100%+)
I would say the durability is pretty darn good. I have been running the zx6 for about 3 months now pretty much every week. Only parts I have broken is a shock shaft, steering knuckle and a front arm.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-26-2015, 05:52 PM   #1263
Does the kit come with sway bars
Old 01-26-2015, 08:04 PM   #1264
Potoczak's Avatar
Yes it does. Not sure of the sizes though.
Pete Potoczak
Old 01-26-2015, 09:01 PM   #1265
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
1.1mm front
1.2mm rear
That is if I measured them right.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 01-27-2015, 05:32 AM   #1266
Trader Rating: 48 (100%+)
Originally Posted by Teufel Racing View Post
1.1mm front
1.2mm rear
I believe the kit comes with 1.0 front and 1.2 rear
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-27-2015, 07:58 AM   #1267
Trader Rating: 21 (100%+)
I have the one piece shock caps for the big bores, but I'm not sure what shock stands I'm suppose to use. Does anyone have a part number? Thanks homies.
joel45acp is offline   Reply With Quote
Old 01-27-2015, 11:13 AM   #1268
WNRacing's Avatar
Trader Rating: 34 (100%+)
http://www.exotekracing.com/rb6-shock-post-set/
Delrin
-Evan Williams
SMC Racing - Airtronics - Radiopost Servos - Upgrade RC
WNRacing is offline   Reply With Quote
Old 01-27-2015, 02:32 PM   #1269
Originally Posted by WNRacing View Post
is there any other options besides those? metal to metal is no bueno in my book. lol
Old 01-27-2015, 02:39 PM   #1270
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I use the stock plastic bushings.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-27-2015, 03:51 PM   #1271
WNRacing's Avatar
You can always use the stock bushings.
The black exoteks are delrin plastic, not metal.
-Evan Williams
Old 01-27-2015, 04:22 PM   #1272
great, would you know the part number? I cant seem to find it anywhere unless I'm overlooking it.
Old 01-27-2015, 04:59 PM   #1273
WNRacing's Avatar
I believe they are on a parts tree iirc. Just look up shock parts on amain.
FWIW the AE guys run aluminum bushings and caps with no problems, part of the reason why I went ahead and got the aluminum Exotek's for my car. The plastic bushings just seem like they wear a lot. The added benefit is also that they help strengthen the shock screws a bit.
-Evan Williams
Old 01-27-2015, 05:21 PM   #1274
Thanks for the input sir. I believe I found them, but the only issue is that there's only two bushings per tree.
Old 01-27-2015, 06:07 PM   #1275
WNRacing's Avatar
http://www.amain.com/kyosho-plastic-...ts-set/p273741
KYOUM753-1
The ZX6 uses the bushings with the short shoulders.
You'll still have to buy two if you're needing a full set.
-Evan Williams
