    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 01-07-2015, 06:04 AM   #1201
Brian C.'s Avatar
Originally Posted by dylanshock View Post
before this buggy I had sworkz s104 and team c ... TM4 not the first buggy that use I assure you ... and for 5 years I do races in Italy ... I might seem safe me..ma of the problem not until I ... just a landing from a jump is not perfect and it breaks ... made of paper kyosho
could just be very bad luck, kyoshos seem to be fairly durable...
Brian C. is offline   Reply With Quote
Old 01-07-2015, 07:00 AM   #1202
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
A lot of times it isn't the last crash to break something it is the one before that and you don't realize it and you continue on until that last crash. Almost every thread has a comment from someone where they say they just tapped a board/pipe/barrier and it ripped off the front/rear arm.
Now I am not saying that is what happened in your case but it is something everyone should think about.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-07-2015, 08:26 AM   #1203
very true. My 22-4 front tower has a large crack I found this morning. Next light tap and it's done.
scoobyrs25 is offline   Reply With Quote
Old 01-07-2015, 08:28 AM   #1204
Gayosaka's Avatar
Kyosho plastics seem to be more brittle than others when it is freezing.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 01-07-2015, 10:48 AM   #1205
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Yeah they break easier in the cold. The 1/8 guys boil their parts.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-07-2015, 01:41 PM   #1206
aloksatoor's Avatar
Any one done the zack rogers setup change on the rear of the zx6? I.e. third hole drill on rear rb6 arms. Would effectively make the rear softer by standing it up. I am gonna try it this weekend.
Old 01-07-2015, 01:57 PM   #1207
rcgod's Avatar
Trader Rating: 27 (100%+)
I tried the Tebo setup where he did the same thing. It was ok still not as good as my car feels with saddles.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 01-08-2015, 12:57 AM   #1208
know how to mount sway bar with rear arms rb6 ??
dylanshock is offline   Reply With Quote
Old 01-08-2015, 03:40 AM   #1209
You need to buy the sway bars for the RB6.
potatobed409 is offline   Reply With Quote
Old 01-08-2015, 04:03 AM   #1210
I saw the setup of Tebo using rear arms rb6 .... in these days of testing on the wet slips back a lot ... with these arms remains more stable ??
Old 01-08-2015, 05:17 AM   #1211
They help but it still wants to step out on me.
Old 01-08-2015, 05:22 AM   #1212
The flat arms with a 3rd hole drilled lock the rear in more than RB6 arms with a 3rd hole drilled.
Kyosho UK RB6.6 & ZX6.6
RogerM is offline   Reply With Quote
Old 01-08-2015, 06:13 AM   #1213
Trader Rating: 48 (100%+)
Are u drilling them 17.5mm from sway bar
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-08-2015, 09:53 AM   #1214
tef
Did you try the setup i posted on the last page? It will help what you are feeling.
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 01-08-2015, 10:25 AM   #1215
aloksatoor's Avatar
Cool Ill also throw it on there since I have a few arms for the rb6 lying around.
