    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 12-31-2014, 11:33 AM   #1186
tef
Here is a pic, sorry if its not great. If this doesnt work or readable I can scan it in when I get home ( Currently in PA).
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 12-31-2014, 01:10 PM   #1187
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Nexus View Post
Anyone actually use "pro-squat" in the rear like in Tebo's setups?
Most of what I've run in the past and currently was always flat or anti-squat. What would pro-squat do for the car or why would one use pro-squat.
From my measurements with 1mm front and 2mm rear the hinge pin angle is zero. Looks like the arm mounts have 1 degree built in anti squat with no shims.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-31-2014, 01:44 PM   #1188
Trader Rating: 37 (100%+)
cool.
Anyone else running 13.5? Gearing? I have been using a 32T and seeing wonderingt what range of pinions guys are running with motor X.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 12-31-2014, 03:11 PM   #1189
golferdude1971's Avatar
Trader Rating: 18 (100%+)
cool.
78/21 is what I have been using at LITH.
golferdude1971 is offline   Reply With Quote
Old 12-31-2014, 04:25 PM   #1190
cool...sorry I meant to say 23 not 32 :P
Old 01-01-2015, 07:23 AM   #1191
tef
Arn0 added this setup to petitrc under low grip base setup if you want to see the actual PDF. Just FYI
Old 01-02-2015, 11:08 AM   #1192
hmmm I wonder if any team Kyosho guys could confirm this. It would be strange because to run anti squat in back you would have to run at least 3mm or more under the front block. I'm not even sure how much clearance there is over it.
Old 01-02-2015, 02:07 PM   #1193
rcgod's Avatar
No shims gives 1 deg anti squat. So 2mm front nothing rear should give 3 degrees.
Dialed RC Hobbies
Old 01-02-2015, 07:12 PM   #1194
Trader Rating: 129 (100%+)
Default gear diff's vs ball diffs
What are everyone's thoughts on 2?
skyline1015 is offline   Reply With Quote
Old 01-02-2015, 07:52 PM   #1195
Potoczak's Avatar
Trader Rating: 111 (100%+)
I'm running gear diffs in my zx6 at critters and seems to be working pretty good. Haven't tried the ball diffs yet.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-03-2015, 12:44 PM   #1196
So far I'm liking the balls diffs and no rebuilds after 3-4 race days. I run 13.5 so the wear is not as high as low turn mod motors.
I like the idea of less maintenance with the gear diffs and I run on mostly high traction dirt/clay tracks. Planning to get a set to compare and for sure in the summer when I run on the outdoor carpet track.
Thanks.
Old 01-06-2015, 04:26 PM   #1197
Hello everyone ... I tested a ZX6 for two weeks ... I only have 3 outputs with this buggy ... for now I am very disappointed ... the car and very fragile ...
for now I broke:
3 front arms
1 rear armas
1 rear hub
1 shocks shaft after collision with another car
And 3 bearing rear hub exploded
local track in turn with 7-10 degrees temperature ... in Italy at this time it's cold. But some friends have hb D413, dex410 and xB4 2015 ... running smoothly breaking ... now I'm wondering where to put the quality kyosho.
Another friend of mine with ZX6 has broken ... we took the kit from futaba pro shop ... are really desperate ... is the first buggy that has these problems ... in 5 years I have never seen anything like it .
I state that I also have a rb6 with I am very well.
I'm really thinking of giving away ZX6 with 30 minutes ride ...
dylanshock is offline   Reply With Quote
Old 01-06-2015, 08:14 PM   #1198
If you broke all those parts in 30 minutes, your doing something wrong.
potatobed409 is offline   Reply With Quote
Old 01-06-2015, 10:42 PM   #1199
before this buggy I had sworkz s104 and team c ... TM4 not the first buggy that use I assure you ... and for 5 years I do races in Italy ... I might seem safe me..ma of the problem not until I ... just a landing from a jump is not perfect and it breaks ... made of paper kyosho
Old 01-07-2015, 04:47 AM   #1200
I've been running the ZX6 since it came out and as yet the only thing I've broken is a front wishbone after a full chat crash into a concrete wall thanks to some muppet stopping dead on a straight!
Car is VERY strong in my opinion and I'm in the UK ... cold here at the moment!
Kyosho UK RB6.6 & ZX6.6
RogerM is offline   Reply With Quote
