    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 12-26-2014, 07:56 AM   #1171
1fastdude's Avatar
Trader Rating: 15 (100%+)
Default ZX6 Ball Diffs
Just built my ZX6 and was curious as how to set the ball diffs up?
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 12-26-2014, 10:39 AM   #1172
Trader Rating: 14 (100%+)
I run a fairly tight rear and looser front. for me a looser front allows me to tame the power down in turns and in the air so it is more controllable for me. tight rear for that traction and zip.
RBraswell is offline   Reply With Quote
Old 12-26-2014, 05:36 PM   #1173
Default Motor
Originally Posted by aloksatoor View Post
hw 3.1 v10 4.5 motor stock spur 14t pinion.
Wow much tighter motor than I guessed
katoom007 is offline   Reply With Quote
Old 12-29-2014, 10:01 AM   #1174
Trader Rating: 37 (100%+)
Interesting. I think most run a tighter front than rear, but everyone likes something different.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 12-30-2014, 07:41 AM   #1175
Trader Rating: 132 (100%+)
hey guys, do any other wheels like the 22-4 fit the zx6?
skyline1015 is offline   Reply With Quote
Old 12-30-2014, 09:32 AM   #1176
Potoczak's Avatar
Trader Rating: 112 (100%+)
I guess they are the same size.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 12-30-2014, 09:35 AM   #1177
Potoczak's Avatar
Don't know of any other 4wd's that have a regular 12 mm hex. Maybe the yokomo bmax.
Pete Potoczak
Old 12-30-2014, 10:41 AM   #1178
aloksatoor's Avatar
Trader Rating: 42 (100%+)
yep I use the AE mono wheels sometimes. Still like the kyosho softer ones more grip and stay whiter longer than most.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-30-2014, 10:43 AM   #1179
thanks guys. i have a bunch of 22-4 wheels that i use on my D413. they are 12mm hex
Old 12-30-2014, 07:07 PM   #1180
Anyone actually use "pro-squat" in the rear like in Tebo's setups?
Most of what I've run in the past and currently was always flat or anti-squat. What would pro-squat do for the car or why would one use pro-squat.
Old 12-30-2014, 09:07 PM   #1181
tef
I run the rear hangers flat, no shims. I tried running shims but wasnt a fan of the high rollcenter. Car comes around too much on exit and it never felt consistent exiting on our low-med/med tracks. Thats for the rear, I do like .5 shims in the front of the car to take away a little nervousness.
I have a low-med/Med setup if anyone cares to try it, its allot different from what the norm is but curious if someone will try it on lower bite tracks.
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 12-31-2014, 03:45 AM   #1182
Trader Rating: 50 (100%+)
Let's see it, I'm game to try a different setup
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 12-31-2014, 03:52 AM   #1183
Potoczak's Avatar
Would be interested in seeing it.
Pete Potoczak
Old 12-31-2014, 06:59 AM   #1184
tef
I filled out an editable setup sheet but will not let me attach it because the file is to big....any suggestions?
Old 12-31-2014, 09:47 AM   #1185
rcgod's Avatar
Trader Rating: 27 (100%+)
Take a picture and post it. Or a screen shot.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
