    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 12-23-2014, 05:13 AM   #1156
Brian C.'s Avatar
Finally got mine built can't wait to race it!!!!
Brian C. is offline   Reply With Quote
Old 12-23-2014, 09:04 AM   #1157
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
[QUOTE=dMITIj;13736529]Can anyone provide me with the right size bearing for the inside and outside for the Aluminum rear v2 hubs? so i dont have to use the provided inserts.
best regards.[/QUOTE/]
You know you can't run the V2 hubs without the plastic insert right? The bearing sizes are 5 x 10 for the inside and you can run three different sizes on the outside 5 x 10, 5 x 11, 5 x 13. Amain sells the inserts separately. http://www.amain.com/kyosho-v2-hub-b...ar-set/p261906
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Old 12-23-2014, 09:42 AM   #1158
dMITIj's Avatar
[QUOTE=motorfinger;13736929]
Thanks for the info ;-)
But if i can find a bearing that fit without the plastic insert why is that not gonna worke?
dMITIj is offline   Reply With Quote
Old 12-23-2014, 10:22 AM   #1159
You probably could but why would you? The plastic helps prevent wear on the aluminum hub. After a while the aluminum will wear and there will be slop between the bearing and the hub. I recommend the plastic inserts.
Old 12-24-2014, 12:55 AM   #1160
dMITIj's Avatar
Thanks! I had not thought of that ;-)
Merry Christmas to you all
Old 12-25-2014, 07:19 AM   #1161
Just bought a roller zx6. What motor and ESC is everyone running? Thanks
katoom007 is offline   Reply With Quote
Old 12-25-2014, 08:08 AM   #1162
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
For those of you running just the shorty pack with the motor in the rear, did you put the speed control behind the battery or towards the front near the servo?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-25-2014, 10:03 AM   #1163
Trader Rating: 48 (100%+)
I run mine opposite side of servo, a buddy of mine runs his behind the motor. Not sure if we could tell a difference
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 12-25-2014, 03:22 PM   #1164
anyone>>:::????
Old 12-25-2014, 03:24 PM   #1165
Trader Rating: 84 (100%+)
anyone>>:::????
I run an orion 8.5 vst motor and an orion r10 pro esc if that helps. Geared stock spur and 21 tooth pinion.
mike_d is offline   Reply With Quote
Old 12-25-2014, 03:54 PM   #1166
Potoczak's Avatar
Trader Rating: 111 (100%+)
I originally had a 6.5 in mine at first. It was to hard to drive consistently. Switched to a 8.5 and my lap times have dropped. I running a reedy 8.5 and a trackstar gen 2 speedo.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 12-25-2014, 04:42 PM   #1167
thanks guys
Old 12-25-2014, 04:59 PM   #1168
rcgod's Avatar
Trader Rating: 27 (100%+)
anyone>>:::????
Hobbywing v3.1 esc and reedy 5.5 or 6.5 motor.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-25-2014, 07:02 PM   #1169
Trader Rating: 14 (100%+)
Viper vtx10 and reedy 7.5
RBraswell is offline   Reply With Quote
Old 12-25-2014, 07:42 PM   #1170
aloksatoor's Avatar
Trader Rating: 42 (100%+)
hw 3.1 v10 4.5 motor stock spur 14t pinion.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
