    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 12-15-2014, 11:09 AM   #1141
kdeleon's Avatar
You have to be part of the Savers Club and even then I think you have to add a few dollars to your order to get to $100. (That is on my account at least.)
kdeleon is offline   Reply With Quote
Old 12-15-2014, 03:42 PM   #1142
Potoczak's Avatar
Trader Rating: 111 (100%+)
Originally Posted by Potoczak View Post
Has anyone tried to fit a center diff into the zx6??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 12-15-2014, 05:10 PM   #1143
rcgod's Avatar
Trader Rating: 27 (100%+)
01002 is the code for 100 off 585. You have to be a super saver member.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-16-2014, 03:54 PM   #1144
Can anyone tell me what spur and pinion combo to run on the Kyosho ZX6. I'm running a 10.5 turn motor on medium bite clay track.
gearit is offline   Reply With Quote
Old 12-16-2014, 04:59 PM   #1145
Brian C.'s Avatar
Just realized I thanked my self...
Brian C. is offline   Reply With Quote
Old 12-17-2014, 03:00 PM   #1146
Try a 25t with the stock spur. Just watch your temps first time out.
Tom87 is offline   Reply With Quote
Old 12-17-2014, 05:43 PM   #1147
vikingen's Avatar
what's your gearing / motor Tom ?
finally happy with my zx6. was mad by the finals at casso last weekend
vikingen is offline   Reply With Quote
Old 12-22-2014, 12:06 PM   #1148
aloksatoor's Avatar
Trader Rating: 42 (100%+)
any one here has been able to fit a dcj without grinding the diff cups? I have a xray set from spec r but thinking if the durango is a drop in I would like that better.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-22-2014, 12:50 PM   #1149
Trader Rating: 48 (100%+)
What's a dcj?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 12-22-2014, 12:57 PM   #1150
rcgod's Avatar
Anyone tried saddles yet? I've tried several online tebo setups and I'm still way off pace compared to my xb4 2014. I also picked up the gear diffs but haven't tried them yet. Running med bite indoor clay.
Dialed RC Hobbies
Old 12-22-2014, 02:00 PM   #1151
Durango has 2,5 mm dogbone-pin, and it is to long. The axel has 1,5mm pin and will not fit a Kyosho 12mm hex.
hloland is offline   Reply With Quote
Old 12-22-2014, 02:05 PM   #1152
aloksatoor's Avatar
ooh then the xrays gonna be put in next rebuild with some dremel work,
DCJ is a dual cardan joint, helps prevent chatter on power with the steering turned all the way to one side. Helps on sweepers and used on TCs. It has two joints at the axel side instead of a cvds 1 joint so the angle is reduced for each joint compared to a single cvd.
Old 12-22-2014, 03:02 PM   #1153
Holmberg418's Avatar
Try motor forward with a shorty. Servo and shorty on one side and everything else on the other side. With gear diff's it takes a while to get use to the driving style. But I am liking 4 front 3 rear.
Kyosho America, Lunsford, Stickit1racing, Jconcepts, JTP
Full Throttle R/C Raceway www.ftrcr.com
510 Raceway
Holmberg418 is offline   Reply With Quote
Old 12-22-2014, 03:07 PM   #1154
rcgod's Avatar
Ok thanks I'll give it a try.
Dialed RC Hobbies
Old 12-23-2014, 04:58 AM   #1155
dMITIj's Avatar
Originally Posted by negatv1 View Post
Aluminum rear v2 hubs are a nice upgrade/option as well.
Originally Posted by tel View Post
Yes they are but please use the 5x13 outer bearing. You can use the stock bearings with the provided inserts but they don't last near as long as going with the larger outer bearing.
Can anyone provide me with the right size bearing for the inside and outside for the Aluminum rear v2 hubs? so i dont have to use the provided inserts.
best regards.
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
