    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 11-12-2014, 10:05 AM   #1066
Potoczak's Avatar
Trader Rating: 111 (100%+)
Originally Posted by aloksatoor View Post
Someone in the thread made the xray spec r ones work. Machined the diff cups to fit 3mm pins.
Hmm that might be an option.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-12-2014, 11:18 AM   #1067
ColbyRichards's Avatar
What are people's shock set ups? I'm lost on springs and Pistons
Retired
ColbyRichards is offline   Reply With Quote
Old 11-12-2014, 11:35 AM   #1068
Tony Marks's Avatar
Usually I run:
Front: 1.6 2-hole pistons, 35wt, gold or yellow springs.
Rear: 1.6 2-hole pistons, 30wt, gold springs.
Team Kyosho America - VP Powermaster
JConcepts - 92zero Designs
Full Throttle/510 Raceway
Jared Tebo Products
Tony Marks is offline   Reply With Quote
Old 11-12-2014, 01:38 PM   #1069
Originally Posted by Tony Marks View Post
Usually I run:
Thanks I try it out
Retired
Old 11-12-2014, 04:08 PM   #1070
Potoczak's Avatar
I'm running the 2x1.6 pistons front and rear. 35wt front with gold spring. 30wt rear with white spring. Running the buggy on medium to low bite clay.
Pete Potoczak
Old 11-12-2014, 06:14 PM   #1071
tef
I tried 3x1.4 front/yellow/35 and 4x1.3 rear/gold/30 and it was great. Got in nice and didnt swing the rear around on exit.
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 11-12-2014, 06:25 PM   #1072
3srcracing's Avatar
Trader Rating: 25 (100%+)
If anyone is looking to sell their Zx6 hit me up, looking for one.
3srcracing is offline   Reply With Quote
Old 11-15-2014, 06:36 AM   #1073
I received carbon parts from Bezerk RC
They look very good.
hloland is offline   Reply With Quote
Old 11-15-2014, 06:52 AM   #1074
I have a couple of questions, when I look at a lot of set ups people are shaving down the front and rear arms,why are they doing this, to get them to turn ? then are they running thick oil to compensate ? I have not run mine yet ,trying to understand . thnx
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 11-16-2014, 05:37 AM   #1075
I'm not sure of there reason for doing it but I tried it and it helped on corner exit. I had problems getting back on throttle exiting corners and after several changes including shaving the arms it drives very consistent.
potatobed409 is offline   Reply With Quote
Old 11-16-2014, 06:52 AM   #1076
Potoczak's Avatar
Did you shave just the rear or front and rear??
Pete Potoczak
Old 11-16-2014, 09:52 AM   #1077
I shaved the front and rear. If you shave it down and don't like it you can always add spacers and space it back out. I was worried about it weakening the arm but after some horrible crashes it's still held up well.
Old 11-16-2014, 10:17 AM   #1078
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
which ball stud is everyone running to be able to run the 4mm bump steer washers? the stock one is to short.
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 11-16-2014, 10:50 AM   #1079
Potoczak's Avatar
I changed my whole car over to the tlr ball studs with the with the 2mm hole on top and just made holes in my kyosho ball cups. The tlr ball studs come in 6mm or 8mm length.
Pete Potoczak
Old 11-16-2014, 10:53 AM   #1080
Potoczak's Avatar
Did you then move the arms toward the center for a shorter wheel base?? I'm also searching for a little bit of grip coming out of corners. I have to wait to square up staight then throttle it or it will want to kick out a little.
Pete Potoczak
