    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 09-29-2014, 10:51 AM   #976
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Cars a keeper for me. Tonnes of steering and still hooks up crazy on throttle pulls. Durability is at least as good as the xray (without the shitty pinion issues) and definitely seems like a keeper.
The first heat (never ever driven the car before) I shaved half a second a lap off the xrays time. Car had hella steering so was super inconsistent but it has a lot of potential with a few practice/setup days, just the factory setup with orange fronts and white rears everything else stock.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 09-29-2014, 02:26 PM   #977
Potoczak's Avatar
Trader Rating: 111 (100%+)
What setup did you put on the car?? What kind of track were you running on??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-29-2014, 02:42 PM   #978
aloksatoor's Avatar
The setup from the manual as I built her up. Stock front pills, CC in RF and FF out RR and also rb6 rear arms I had spare from my mod 2wd. Stock roll centers antisquat caster etc. 30 and 25 losi oils 1.6 kit pistons medium shock ends all 4. Ride height 21 front and 21 in the front spot in the rear (as per sheet). I always set my throttle return speed on the radio to be exponential, helps keep corner speed up and braking seems better to me. Never run drag brakes.
Track is super high bite with small twisty section with one long straight. Only had a 8.5 motor in the car and it was enough. Love the way it drives!
I also added the front pin (which goes through the slot in the diff screw as per manual), to calm her down and it helped a lot. Without it the car was too nervous for me. Front diff is tight as possible, rear is looser (can't quantify it like gear diffs but went by feel).
Running skinny shorty (150 grams), burned 1700mah in a 6 min main with 5 laps of warm up so not too shabby (car is efficient). RTR 1620 grams. Car does not need any upgrades at all can't praise that part enuff!!
Old 09-29-2014, 03:38 PM   #979
Potoczak's Avatar
Thanks for all the info. What do the rb6 arms do for the car??
Pete Potoczak
Old 09-29-2014, 03:49 PM   #980
aloksatoor's Avatar
haha don't beat me up for it, but I never ran the stock arms so cannot say. I like my arms to be parallel to the ground/dogbones when I do ride height changes (the stocks won't let you do that) - I know dumb reason lolz.
you do have to use longer shock ends than you use with the flat arms though since the shock mount pt is lower with gull wings.
Old 09-30-2014, 05:25 AM   #981
99windy's Avatar
Post drive shaft length
Guys,
Could some one please measure the length of both centre shafts, i need pin to pin, and over all if possible.
Reason is i have a DB4 converted zx5. which is the same as having the motor at the front on the zx6, but i am running saddle packs. May be thinkng of doing shorty conversion when i get chance.
any help you can give is great
can put some pics up if you want to see a post ZX5, pre ZX6 car
Cheers
Lee Willows
TLR 22-4 HW Inside
TLR 22 2.0 HW Inside
Moss Models.
Horizon Hobby
99windy is offline   Reply With Quote
Old 09-30-2014, 06:36 AM   #982
Gayosaka's Avatar
Hi Lee, RogerM gave me the answer on oOple:
front 86mm, rear 60mm, pin to pin.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 10-02-2014, 01:47 PM   #983
Potoczak's Avatar
Question for the guys running the rb6 arms on the rear. How is everyone mounting the swaybar on the arms?? The rb6 arms don't have the stud molded in.
Pete Potoczak
Old 10-02-2014, 02:08 PM   #984
aloksatoor's Avatar
One friend mounted the plastic balls by cutting them from flat arms, drilling them and using a set screw. I used a threaded ball I had from a touring car with a set screw on the outside of the arm. Think it was this guy http://www.spec-r.com/default/index....roducts_id=413 to get it as close to the arm as possible.
Alternatively can use the http://www.amain.com/Kyosho-48mm-Low...Stud-4/p151052 to get it as snug to the arm as possible.
If you want factory then get the rb6 sway bar mount.
Old 10-03-2014, 11:06 PM   #985
Holmberg418's Avatar
Use KYOUMW708-01 when you run rb6 rear arms if you want to run sway bars also.
Kyosho America, Lunsford, Stickit1racing, Jconcepts, JTP
Full Throttle R/C Raceway www.ftrcr.com
510 Raceway
Holmberg418 is offline   Reply With Quote
Old 10-04-2014, 03:28 PM   #986
KalEl63's Avatar
I finally raced this at a club meeting yesterday and had as blast with it.
The only thing was the rear end just wanted to squat down so much that the weight transfer from front to rear was massive and unsettled the car.
Not sure what I'll try first to adjust this out a bit.
I'm running kit set up with 35WT/3x1.4 front and 30WT/2x.1.6 rear plus shorty battery and rear motor
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 10-04-2014, 05:00 PM   #987
Try 40wt/2x1.6 front with yellow front springs.
510 Raceway
Old 10-04-2014, 06:40 PM   #988
KalEl63's Avatar
I think it's more to do that the rear is too soft but I'll give your suggestion a go as I'm always up to try what people suggest.
I'm also going to put RB6 rear arms on to see what they are like so I have two questions for those who have.
Did you shim it 2mm to the front of the inner rear hinge pin?
With UMW708-01 I have all those parts but does what is the length of the button head screws in it?
1.21 GIGAWATTS!!!
Old 10-05-2014, 07:26 AM   #989
reduce rear droop maybe??
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 10-05-2014, 09:04 AM   #990
kwilke's Avatar
Trader Rating: 172 (100%+)
Send a message via AIM to kwilke
is the majority of people running rear motor with shorty lipo?
Bluegrass Hobbies
www.bluegrasshobbies.com.
kwilke is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
