    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree9Likes
Old 09-18-2014, 10:54 PM   #961
JarrodP's Avatar
Originally Posted by WagwanBumba View Post
All those pieces of CF are 40g lighter than their combined plastic equivilents?! That's some awesome looking CF! How thick are the suspension towers?
Yep.. topdeck uses less screws which helps lighten it too. 4mm towers. Contact Paul at Bezerk Rc
Kyosho Inferno MP9e - Inferno ST-RR Evo ep - Ultima RB6 -Lazer ZX6 - Ultima SC6 - Ultima RT6
Tamiya XV-01 Rally
JarrodP is offline   Reply With Quote
Old 09-19-2014, 01:38 AM   #962
JarrodP's Avatar
CF topdeck vs plastic braces. Also a difference of 3g in battery straps.
The screws you see are the ones that aren't used with the topdeck.
Tamiya XV-01 Rally
Old 09-19-2014, 03:07 AM   #963
Would be interested to know how this will affect handling of the ZX6. Early pre-release pictures show ZX6 with top deck, but removed from the production release, suggesting that it caused detrimental handling to the buggy?
There an option of 3mm towers?
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 09-19-2014, 03:26 AM   #964
JarrodP's Avatar
I saw that, it was a pretty solid top deck and the chassis didn't look milled out at all.
Not sure about 3mm towers. Hit up Paul at Bezerk Rc on Facebook.. very helpful guy.
Tamiya XV-01 Rally
Old 09-20-2014, 07:30 PM   #965
Jochim_18's Avatar
Originally Posted by Gayosaka View Post
Any feedback on that layout? I'm thinking about trying that on my old FS2.
U like it this setup better than rear motor configuration. .
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 09-21-2014, 06:48 PM   #966
Has anyone ran the shorty and saddle configuration to compare differece? I had my 22-4 w saddles and liked it. But i put shorty in zx6 and it feels really light which is good for some drivers. I persobnaly think I'm better with a little more weight.
turehd73 is offline   Reply With Quote
Old 09-27-2014, 08:15 AM   #967
Potoczak's Avatar
Trader Rating: 112 (100%+)
Ok so I'm in the middle of the build. I'm at the point where the center slipper goes in with the center driveshafts. It seems like the front center one is to short. Has anyone else had this problem?? Solution or a fix??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-27-2014, 08:51 AM   #968
mourinho's Avatar
Trader Rating: 42 (100%+)
page 21 of the manual, step 25, make sure you have the plastic spacer (la200) installed in the outdrive facing the front.
mourinho is offline   Reply With Quote
Old 09-27-2014, 12:04 PM   #969
Trader Rating: 38 (100%+)
LAW50 2 gear diffs new selling. Just letting you know it is posted in for sale section. 518-495-0703
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 09-27-2014, 07:32 PM   #970
KalEl63's Avatar
Ok maybe a silly question but what is the best way to tighten/adjust the ball diffs while in the car?
I haven't had a 4WD with ball diffs before
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 09-28-2014, 06:13 PM   #971
JarrodP's Avatar
Pop the camber link to get the the driveshaft out of the way, a 2mm Allen key can be put in the out drive to adjust. You may have to remove wheel and/or drop the shock so driveshaft clears.
Tamiya XV-01 Rally
Old 09-28-2014, 09:10 PM   #972
KalEl63's Avatar
yep that is exactly what I ended up doing I was just hoping I was missing the obvious
1.21 GIGAWATTS!!!
Old 09-28-2014, 09:47 PM   #973
If you don't like taking the ball cup off (I don't), just wip the lower hinge pin out. You can leave the shock on this way
Tom87 is offline   Reply With Quote
Old 09-28-2014, 09:53 PM   #974
So what setup are people running?
I'm still looking for some entry/mid corner steering (off power). I'm looking for some front end adjustments as I'm very happy with the rear currently.
Thinking of reducing front kick up, maybe narrow the front end? What caster block is everyone running? Im at 10*
Old 09-29-2014, 04:48 AM   #975
Trader Rating: 55 (100%+)
Post ur setup, I'm actually going from 7* to 10* hoping that it give me more corner entry. I'm running b in right now but might go to c in
Speedychris22 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
