    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 08-22-2014, 08:19 AM   #796
Trader Rating: 71 (100%+)
"Needs" nothing out of the box. But, some possibilities might be-
Springs for tuning - Comes with gold/gold F/R. Orange/Yellow nice to have up front, maybe red/white for the rear.
Alumium servo horn? Unless you are a plastic/'saver' kind of guy.
As far as 'bling' goes - already has the gunmetal hexes, shock caps, hinge pin mounts,etc. As it should for a >$500 kit.
Aluminum battery posts with the thumbscrews are a nice addition. Comes with two sets, so if running shorty will have a spare, or set to sell to another zx6 owner.
negatv1 is offline   Reply With Quote
Old 08-22-2014, 09:01 AM   #797
Trader Rating: 38 (100%+)
THANKS FOR THIS INFO
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 08-22-2014, 10:35 AM   #798
Rybeau40's Avatar
Hearing I need to shim the center diff/slipper. What shims are being used to take out the play so the spur gear doesn't strip?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 08-22-2014, 10:51 AM   #799
I used a single thin shim (.02-ish) of the appropriate size for the slipper assembly bearings (don't have the size handy). The amount of play likely varies from car to car, so will just have to adjust needed thickness by feel.
Old 08-22-2014, 10:51 AM   #800
Aluminum rear v2 hubs are a nice upgrade/option as well.
Old 08-22-2014, 10:56 AM   #801
tel
Yes they are but please use the 5x13 outer bearing. You can use the stock bearings with the provided inserts but they don't last near as long as going with the larger outer bearing.
Travis Lewis
Team Kyosho, Orion, KO Propo America, Avid RC
tel is offline   Reply With Quote
Old 08-22-2014, 10:56 AM   #802
Are the hubs the same as the RB6?
potatobed409 is offline   Reply With Quote
Old 08-22-2014, 11:14 AM   #803
Rybeau40's Avatar
What brand/type of shims were you using?
Futaba 4PLS
Support your LHS.
Old 08-22-2014, 11:30 AM   #804
Yes, they are the same.
Old 08-22-2014, 11:39 AM   #805
No idea what brand I used. Looked up the bearing is 10x15x4mm - I went on the inside of the bearing, so something around 10mm, and very thin so you don't bind things up.
Old 08-22-2014, 08:14 PM   #806
Jochim_18's Avatar
Gonna start the build this week. What is the consensus on saddle vs. shorty for medium traction indoor clay/dirt mix?
I tried rear motor with shorty pack. For me buggy is unpredictable mid air and it just bottoms out on landing. I have seen setup which they have more pack on the rear than on the front which I don't think it's a good idea traction wise. I took mine a part and switching back to front motor setup which I like better buggy jump better and it doesn't bottom out.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 08-22-2014, 11:09 PM   #807
Trader Rating: 16 (100%+)
Send a message via Yahoo to Zach Phillips
Does anyone know what the part number is for the ZX6 Gear Differential outdrives is? I cant find a ZX6 specific part number, but don't know what parts are shared.
KYOSHO | JCONCEPTS | ORION | SMACTRAC |
Zach Phillips is offline   Reply With Quote
Old 08-23-2014, 12:22 AM   #808
I'm almost certain it's UM612, shared with the geared diff from the SC etc, if someone has to hand the LAW50 diff build instructions it gives the part number for the outdrive.
There are velvet coated diff ally bevel shafts available to...TFW008
njc11 is offline   Reply With Quote
Old 08-23-2014, 01:25 AM   #809
Part number for the gear dif outdrives is TFW125 or TFW009.
UM612 is for RB6 gear dif.
hloland is offline   Reply With Quote
Old 08-23-2014, 03:02 AM   #810
thought they were the same as the RB6/SC shafts... Was that from the geared diff build manual?
