    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 08-17-2014, 09:30 PM   #751
TLRMAN's Avatar
Originally Posted by K_King View Post
Are you putting in set screws in the 2 holes? You need to do that so the bearings stay put. Don't tighten them too much or it will bind (you will hear the difference.)
Just a quick question, have run mine already and it is super smooth and no noises heard, have seen the 2 x holes on the slipper assy cap but the spur/slipper assy does not move up and down when fitted and secured so im not sure why you would want to put the grubscrews in the top, it does however have front to back movement which may contribute to the dog bone popping out but i havent experienced that issue either and hope i dont.
Sponsored by VISA, Mastercard and Acoms
TLRMAN is offline   Reply With Quote
Old 08-18-2014, 12:52 AM   #752
With my old ZX5 i used to have these set screws on the slipper and it worked, however my ZX6 doesn't have that play. Only lenghtwise ist's moving a bit but as said this can be shimmed out easily.
Another question: are the gears on the Gear diff made of steel or plastic? Cannot find any good pics of that...
Egress is offline   Reply With Quote
Old 08-18-2014, 01:08 AM   #753
Its some kind of metal, but not machined cut steel.
hloland is offline   Reply With Quote
Old 08-18-2014, 07:33 AM   #754
Trader Rating: 71 (100%+)
I can see using the grubscrews if slop develops where the bearing rides, but for now there is no vertical slop in mine, just the forward/back that was remedied with a shim.
negatv1 is offline   Reply With Quote
Old 08-18-2014, 10:26 AM   #755
kenny lutz's Avatar
Trader Rating: 36 (100%+)
When you order the law50 is it 1 or 2 diff's?
Kyosho Rb6.6- Maclan mmax - Fantom 17.5
Kyosho Zx6.6- Maclan mmax - Fantom 13.5
Airtronics M12 - Auer Ace Hardware - Schelle
kenny lutz is offline   Reply With Quote
Old 08-18-2014, 10:47 AM   #756
Will a standard servo horn work on this buggy? I'm gonna use a Spektrum S6040 with a straight tekno horn.
potatobed409 is offline   Reply With Quote
Old 08-18-2014, 01:32 PM   #757
Potoczak's Avatar
Trader Rating: 111 (100%+)
Looking at running this buggy in the winter. Is there gear diffs available for the zx6. Also what are parts should i stick up on?? Thanks
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-18-2014, 07:24 PM   #758
kenny lutz's Avatar
Only part that's broke on mine is a front arm. It was my fault that it broke but been solid otherwise
Old 08-18-2014, 07:28 PM   #759
kenny lutz's Avatar
Got gear diffs on the way anyone have any oil suggestions I was thinking 15 and 7 or 5
Old 08-18-2014, 07:58 PM   #760
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
that is to keep the entire assembly from moving, not just up and down, but side to side as well.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 08-18-2014, 08:21 PM   #761
TLRMAN's Avatar
Guess its really up to the individual but i only have front to back movement during the build which i didn't shim just built as per the instructions, may or may not shim it later but can't really see how a single grub screw placed on the top of a round object (the bearing) would stop side to side movement unless you apply a lge amount of force, it would require a grubscrew on the side to set the side ways movement and also where the bearing sits is shaped to hold the bearing so even the grubscrew on the top may have a small effect on this due to the shape of the bearing slot, if you have sideways movement maybe look at replacing the item that is causing the slop. Just my thoughts anyway.
Old 08-18-2014, 08:22 PM   #762
mourinho's Avatar
Trader Rating: 40 (100%+)
So does law50 come with 1 or 2 diffs?
Where did you order from?
mourinho is offline   Reply With Quote
Old 08-18-2014, 08:46 PM   #763
Holmberg418's Avatar
Comes with one diff.
Kyosho America, Lunsford, Stickit1racing, Jconcepts, JTP
Full Throttle R/C Raceway www.ftrcr.com
510 Raceway
Holmberg418 is offline   Reply With Quote
Old 08-18-2014, 08:59 PM   #764
JarrodP's Avatar
I just emailed proshop about them. No reply yet.
They're on eBay for 100 bucks each.
Kyosho Inferno MP9e - Inferno ST-RR Evo ep - Ultima RB6 -Lazer ZX6 - Ultima SC6 - Ultima RT6
Tamiya XV-01 Rally
JarrodP is offline   Reply With Quote
Old 08-18-2014, 10:10 PM   #765
As far as i know it is only 1 diff, quite expensive but i think with all of Kyosho, worth the money.
