    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 08-14-2014, 10:41 AM   #736
Holmberg418's Avatar
The front shaft should be a running change. If you buy a new front shaft it should be longer then the one that came with the first batch of kits.
Kyosho America, Lunsford, Stickit1racing, Jconcepts, JTP
Full Throttle R/C Raceway www.ftrcr.com
510 Raceway
Holmberg418 is offline   Reply With Quote
Old 08-14-2014, 11:51 AM   #737
Trader Rating: 51 (96%+)
We should get a replacement free then...
CaseyDDR is offline   Reply With Quote
Old 08-14-2014, 11:56 AM   #738
I was going to order a kit today from Amain. Is there anyway of knowing if it's a new batch of kits or not?
potatobed409 is offline   Reply With Quote
Old 08-14-2014, 01:53 PM   #739
Trader Rating: 48 (100%+)
i agree there should be a way to contact Kyosho and get a free replacement.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 08-14-2014, 05:31 PM   #740
Why should you get one free? The one that came with the kit works fine. Just use the foam pads or a shock o ring.
510 Raceway
Old 08-14-2014, 05:56 PM   #741
JarrodP's Avatar
But didn't you say it should be a running change and should be longer.
I believe the current length is right.
Shock o rings are too big.. fuel hose is the go
Kyosho Inferno MP9e - Inferno ST-RR Evo ep - Ultima RB6 -Lazer ZX6 - Ultima SC6 - Ultima RT6
Tamiya XV-01 Rally
JarrodP is offline   Reply With Quote
Old 08-14-2014, 05:58 PM   #742
JarrodP's Avatar
There is no new batch. The kit is fine if you build it right.
Tamiya XV-01 Rally
Old 08-14-2014, 07:04 PM   #743
Ok. This will be my first Kyosho car. Hope I'm not disappointed.
Old 08-14-2014, 08:03 PM   #744
Zylux's Avatar
You won't be
Kyosho RB6, Kyosho ZX6, Mugen MBX7E
Zylux is offline   Reply With Quote
Old 08-15-2014, 07:47 AM   #745
I had one issue with my kit but it ran great. The center shafts had a slight bend to them. The front more so than the rear. I couldn't see it until I spun everything over before installing electronics. I submitted a ticket to Kyosho support with a short video of the issue and by the next week I had parts in my mailbox. Kyosho has top notch support. As far as length I didn't see any difference between the front shafts and I haven't had a problem with them popping out. Just make sure you have the foam or o-ring up front and the plastic spacer at the center installed correctly. It is offset. This car has so much more potential than my ZX5 but I need to drive better. You will not be disappointed.
Jeremy Clark
RB6 for Mid, ZX6 and an untold number of Axial crawlers for family fun...
Arcain41 is offline   Reply With Quote
Old 08-17-2014, 07:37 AM   #746
Trader Rating: 71 (100%+)
Noticed that the spur/slipper assembly had a good deal of play in it (shifting forward/back) and was present with other newly built ZX-6's that I looked at locally. Enough play that I could see as possibly contributing to the the center shaft(s) popping out in the right conditions.
I used a single shim (0.2-0.3 or so) on the inside of one of outdrive bearings which took out all of the play. No issues thus far.
negatv1 is offline   Reply With Quote
Old 08-17-2014, 08:23 AM   #747
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Are you putting in set screws in the 2 holes? You need to do that so the bearings stay put. Don't tighten them too much or it will bind (you will hear the difference.)
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 08-17-2014, 09:24 AM   #748
I'm not. I have seen the holes on the center mount top plate that go through to the bearing location, but I just scanned through the manual just now and I am not seeing any mention of using set screws.
But it certainly makes sense to do so - What size setscrews are you using here?
Old 08-17-2014, 09:50 AM   #749
K_King's Avatar
Whatever you have left over. Should be the same as the one that goes into the sway bar mounts.
Old 08-17-2014, 09:52 AM   #750
K_King's Avatar
Here's a setup I have been working on. Super easy to drive and fast. I want to try the stock arms eventually and some different sways but for now this is a easy base setup for me to go off of.
https://dl.dropboxusercontent.com/u/...Aug%202014.pdf
