    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 07-26-2014, 01:50 AM   #631
Trader Rating: 22 (100%+)
Amain is showing in stock for kits,but has no link for Lazer ZX-6 parts yet
Mugen MBX6T O.S. V Spec Limited#214 2060 Pipe JR 9100 servos
Tekno MBX6T MMM Tekin 2000KV Futaba Servos
Tekno MBX6 Tekin RX8 2050KV Futaba Servos
Team Durango DEX410 MMP Ballistic 6.5 Orion Servo
Team Durango DEX410T MMP Ballistic 8.5 Orion Servo
intensebmxer is offline   Reply With Quote
Old 07-26-2014, 05:27 AM   #632
Zylux's Avatar
Originally Posted by joecool View Post
That battery strap looks awesome. I hope kyosho releases one like that for shorty packs.
By the way, you steering rack is upside down.
Thanks. I'll check the steering rack.
Yeah, happy with the strap. I feel like the kit needs a little bling as it's mostly plastic and even just a carbon battery strap makes it look better. The carbon strap is also a couple of grams lighter than the plastic one and stiffer as well (Unlike the Revolution Designs carbon strap I bought for the RB6 which actually weighed 2 grams more than the stock plastic one!). Given that no-one seems to make one for the ZX6 I just bought some carbon sheet and used the scroll saw and belt sander to cut it out. Drilling through the carbon was the biggest problem but I ended up using a carbide ball nose milling cutter at low speed to do the job. Quite easy and simple really and MUCH cheaper (if you don't count the cost of possible health complications . I did wear a carbon filter mask and used good dust extraction etc).
Kyosho RB6, Kyosho ZX6, Mugen MBX7E
Zylux is offline   Reply With Quote
Old 07-26-2014, 06:17 AM   #633
Jpm1's Avatar
Here is mine painted and ready to race weight......
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 07-26-2014, 07:53 AM   #634
hobie814's Avatar
Rudebits already proposed some carbon parts for the ZX6 including battery straps: http://www.rudebits.co.uk/index.php?cPath=111_182
hobie814 is offline   Reply With Quote
Old 07-26-2014, 11:17 AM   #635
Nice, mine just came in yesterday!
R.M.S is offline   Reply With Quote
Old 07-27-2014, 05:16 AM   #636
carbons2k's Avatar
Trader Rating: 21 (92%+)
Anyone know if the zx5 bodies will fit? I wanna send the 6 body out for paint and still run the car...
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 07-27-2014, 08:35 AM   #637
I think they fit, just a little short in the front. There are a couple pics on previous pages in the thread.
Old 07-27-2014, 04:31 PM   #638
kenny lutz's Avatar
Trader Rating: 36 (100%+)
Ran mine yesterday with the stock springs and it had way to much steering causing it to over rate in the corners. Also went with a long shock end as the short didn't have enough droop. Hope to change the front to orange springs then test again.
Kyosho Rb6.6- Maclan mmax - Fantom 17.5
Kyosho Zx6.6- Maclan mmax - Fantom 13.5
Airtronics M12 - Auer Ace Hardware - Schelle
kenny lutz is offline   Reply With Quote
Old 07-27-2014, 04:40 PM   #639
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Man I want more of those little black spongies. I wasnt sure where to put them so I put them on the front shaft section and cut some o-rings to make the rear portion feel similar. The manual doesnt mention what to do with them.
For those running the RB6 arms, are you running it arms forward and hubs forward?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 07-27-2014, 05:02 PM   #640
kenny lutz's Avatar
Sponges go in the center diff according to the manual and yes both forward.
Old 07-27-2014, 06:39 PM   #641
Trader Rating: 48 (100%+)
How's the traction coming out of the corners?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 07-28-2014, 07:45 AM   #642
kenny lutz's Avatar
traction was great everywhere but entry and mid corner as it has to soft of a front and is dumping in the corners
Old 07-28-2014, 09:20 AM   #643
I was thinking of putting the esc in the rear of the motor to keep the weight in the rear. I saw a pic with that setup and the weight looks very even. Are u running the RB6 arms?
My Credit Card
Old 07-28-2014, 09:51 AM   #644
kenny lutz's Avatar
It does I know that's not the issue with mine but might try it sometime
Old 07-28-2014, 10:15 AM   #645
Jochim_18's Avatar
I thought the car has so much steering when I race it Friday night it was undrivable and the front end dives and hits the face of the jump making jump very awkward but went to work with it yesterday all day changing setup after setup and finally nailed it now my KYOSHO ZX6 was on rails it was unbelievable.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
