    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 07-23-2014, 01:00 PM   #616
Look what we just got from Kyosho America! If anyone is interested PM me.
https://www.fastlaprchobbies.com/
Fast Lap RC is offline   Reply With Quote
Old 07-23-2014, 01:27 PM   #617
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Jpm1 View Post
In a 5 minute run at our track with 1 lap warmup and 21.5 second laps the most I put in was 1186mah.
That could go up slightly though as I was running the prototype SMC speedy and only just worked out how to adjust the punch which was set at default lol.
Justin
Nice I will do it for winter indoors then for the balance. My xb4 consumes 1400~1500 mah on a 1/8 size outdoor track for 6 min mains with a 4.5 ~ 140F temps. Still waiting on Tower getting stock for the zx6 .
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 07-23-2014, 07:44 PM   #618
Jochim_18's Avatar
Is their a gear diff available for ZX6? We have big race next month and the track will be sugared.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-23-2014, 08:01 PM   #619
Jinggoy's Avatar
Kyosho global site says Part# LAW50 for ZX6 and release Date July 2014.
https://www.kyosho.com/eng/products/rc/newparts.html
i hope someone try durango diff
Jinggoy is offline   Reply With Quote
Old 07-23-2014, 08:32 PM   #620
KalEl63's Avatar
Futaba Pro Shop has it listed but not sure if they have stock yet
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 07-24-2014, 01:16 AM   #621
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
http://www.petitrc.com/setup/kyosho/...out2014071820/
tebo setup at Hot ROD shootout... check out the 3k front diff oil
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 07-24-2014, 11:35 AM   #622
Jochim_18's Avatar
Ok guys I start the build last night till I got too the center diff and installing the dog bone. It was tight and the driveline is not free and the front dog bone seems a little short. Anyone have this issue?
Old 07-24-2014, 03:41 PM   #623
Can anyone take a few photos of the front tower mount? I always had issues with these on the ZX-5 and want to see if they added a decent amount of material to this area on the ZX-6. Thanks!
AMorgan is offline   Reply With Quote
Old 07-24-2014, 05:01 PM   #624
mourinho's Avatar
Trader Rating: 40 (100%+)
Make sure you have the little clear plastic spacer inserted in the outdrive that is facing the front, I forgot to install it and also thought I had a short dogbone, once its installed its fine.
Cant help on your other point as my drivetrain was very smooth and free, I would just double check your build with the manual.
mourinho is offline   Reply With Quote
Old 07-25-2014, 02:24 AM   #625
Zylux's Avatar
I finally got time to start putting my ZX6 together today. Still waiting on Titanium ball studs and ESC though so progress has stalled.
Picks of Front Tower Mount;
From the back;
And my current state of progress;
Kyosho RB6, Kyosho ZX6, Mugen MBX7E
Zylux is offline   Reply With Quote
Old 07-25-2014, 03:05 AM   #626
KalEl63's Avatar
I see you are trying the RB6 arms I will be keen to see what you think.
How you finding the build so far?
1.21 GIGAWATTS!!!
Old 07-25-2014, 03:17 AM   #627
Zylux's Avatar
Yeah going to try the RB6 arms; partly for the weight saving.
Build has been fairly quick and easy so far, just like the RB6. The longest bit so far was cutting out the carbon battery strap. Also need to mod the battery posts or make some shorter ones as they are too high for the SMC3500 pack.
Old 07-25-2014, 08:45 AM   #628
Jochim_18's Avatar
I figured it out what cause the binding. I put 2 shims on center out drives per manual and that made the driveline tight so I took it out and only put one shims on the front and I did not put anything on the rear and walla butter smooth and the driveline is free.
Old 07-25-2014, 03:55 PM   #629
Trader Rating: 49 (100%+)
Which step are u talking about?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 07-25-2014, 11:48 PM   #630
joecool's Avatar
Trader Rating: 19 (100%+)
From the back;
That battery strap looks awesome. I hope kyosho releases one like that for shorty packs.
By the way, you steering rack is upside down.
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
