    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree9Likes
Old 07-14-2014, 03:12 AM   #556
KalEl63's Avatar
Originally Posted by gelshocker View Post
Do you have a KO servo to test? Sometimes the servo cases are too big?
Originally Posted by Holmberg418 View Post
Move the servo back. Use no shims. Or dremil a little off the mount to move the servo back. Or you can run rotate the servo horn on the other direction.
I don't have a KO servo and looking at the specs the KO is .2mm thinner than the Spektrum but I would have taken a bit more than that off the cup.
Also tried it with the shims out and it makes no difference
I'm sure I'll get it right eventually I just spent an hour on it trying to get it right.
For now the shaved ball cups works as a back up plan to if I don't
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 07-14-2014, 10:25 PM   #557
KalEl63's Avatar
It just dawned on me while sitting here at work maybe Iíve used the wrong servo horn as it didnít want to go on in a hurry.
I used the SK horn is that right for Spektrum S6070 which has 23T spline?
1.21 GIGAWATTS!!!
Old 07-14-2014, 11:20 PM   #558
JarrodP's Avatar
Looks to me like it's your servo. My savox has a step down where yours looks to be hitting.
Kyosho Inferno MP9e - Inferno ST-RR Evo ep - Ultima RB6 -Lazer ZX6 - Ultima SC6 - Ultima RT6
Tamiya XV-01 Rally
JarrodP is offline   Reply With Quote
Old 07-15-2014, 03:28 AM   #559
JarrodP's Avatar
Here's mine on full lock left
Tamiya XV-01 Rally
Old 07-15-2014, 04:02 AM   #560
KalEl63's Avatar
Yep I think you are right the S6070 doesn't have that. What servo is that?
I might look at my 1251 and see how that goes from my RB6
1.21 GIGAWATTS!!!
Old 07-15-2014, 04:43 AM   #561
JarrodP's Avatar
It's a 1258tg(this is the only servo I've tried). But looking at my 1251(different shape again) it could could be close. I think you'll get away with it.
Tamiya XV-01 Rally
Old 07-15-2014, 07:01 AM   #562
KalEl63's Avatar
I tried the 1251 and it still hits.
I had a look at my 1258 in my SC6 and I see why that works and yes you need that little step down it has for the clearance.
So at this point if you use the Spektrum S6070 or Savox 1251 slim servo you need to shave a bit off the ball cup for it to work.
Maybe down the track I'll replace it with a 1258 but at this point I'll see how the S6070 with the shaved ball cup.
1.21 GIGAWATTS!!!
Old 07-15-2014, 08:43 AM   #563
cnelson3's Avatar
Trader Rating: 65 (100%+)
Would a longer servo arm work?
cnelson3 is offline   Reply With Quote
Old 07-15-2014, 11:43 AM   #564
Trader Rating: 91 (100%+)
The link from the servo arm to the bellcrank is too long. You need to shorten it.
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 07-15-2014, 05:55 PM   #565
KalEl63's Avatar
Yeah I think it would, keeping in mind the clearance between the link and the front brace
I have mine with 0 gap and would need to trim some of the threaded end to make it shorter.
I am going to try that that though by trimming about 1mm off the end of one of the ball cups.
Either way if you run either two of the servo's I have mentioned they won't work off the bat without some form of trimming involved.
No biggie to me I still have mine working it's just a matter of conversation and seeing what people have put up to try which has been great
1.21 GIGAWATTS!!!
Old 07-15-2014, 06:39 PM   #566
Also check if your steering links are even. If the left is too long and right too short the rack will be off center and cause that issue.
Old 07-15-2014, 06:56 PM   #567
KalEl63's Avatar
Yep that was one of the first things I did and they are.
1.21 GIGAWATTS!!!
Old 07-15-2014, 09:13 PM   #568
vikingen's Avatar
Trader Rating: 27 (100%+)
dremeled mine a tad so it doesn't hit
vikingen is offline   Reply With Quote
Old 07-16-2014, 05:05 AM   #569
Zylux's Avatar
Originally Posted by Steady14 View Post
Im just about to buy my servo for this, some advise and understanding of your options?
Full size or Low Profile?
Power or Response?
Looking at the KO Propo RSx one10?
I just recently got an RSX One10 Response for my RB6 and was going to get one for the ZX6 but was informed that KO Propo are discontinuing the RSX one10 and that it has been replaced with the BSX2 One10 Response servo. Took the suppliers word for it and got the BSX2; looks pretty much the same, except is all black, and the specs are similar but the BSX has more torque;
BSX2 ; .08s 13.3kg
RSX2 ; .07s 9.0kg
I also assume by the designation that the BSX has a brushless motor.
Couldn't really find any indication online that the RSX had been replaced or info about the BSX2 One10 but it arrived on the doorstep today. Probably a good thing to have the extra bit of torque in the 4wd I guess.
Kyosho RB6, Kyosho ZX6, Mugen MBX7E
Zylux is offline   Reply With Quote
Old 07-16-2014, 08:23 PM   #570
Yep same thing happened to me, my order turned up yesterday and it was a BSX2 One10, i thought the same, no biggy. And yes the extra torque can't hurt!
BSX2 ; .08s 13.3kg
RSX2 ; .07s 9.0kg
Kyosho RB6 + Team Orion + Vampire Racing
Kyosho ZX6 + Team Oron + KO ProPO
MR03 + PN Racing
MB010
KO Propo EX-1
Steady14 is offline   Reply With Quote
