    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 07-11-2014, 08:48 PM   #541
KalEl63's Avatar
I have an issue with the ball cup hitting the top of the servo stopping the stoke and therefore not allowing full lock when turning left.
No doubt it's something I have done just wondering if anyone can shed some light on what I've done wrong?
Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread-img_1913.jpg   Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread-img_1912.jpg   Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread-img_1914.jpg
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 07-11-2014, 09:14 PM   #542
Trader Rating: 48 (100%+)
The only thing that I can think off is ur using the wrong ball stud.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 07-11-2014, 10:20 PM   #543
KalEl63's Avatar
I thought the same so pulled it all apart (twice) to check.
I am at a loss so I just trimmed a bit of the ball cup (similar to what you do with the RB6) to give me that extra ~1mm and now I get the full throw so I'm happy
1.21 GIGAWATTS!!!
Old 07-11-2014, 10:54 PM   #544
joecool's Avatar
Trader Rating: 19 (100%+)
Are you sure your servo arm is perpendicular at center?
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 07-12-2014, 02:13 AM   #545
biggerT's Avatar
Originally Posted by Speedychris22 View Post
That's one beefy tower. Where did it break
Top right corner came off on the diagonal cartwheeled of a jump n the tower found ground first no other damage though for such a big hit
Jesus saves Moses divides and Satan drives a stick
Kyosho rb6 kyosho rudebits db2 kyosho rudebits db4
biggerT is offline   Reply With Quote
Old 07-12-2014, 02:36 AM   #546
jelly's Avatar
anyone else noticed an excessive amount of bump steer on the front?
convinced i've built it wrong but struggling to see what.
jelly is offline   Reply With Quote
Old 07-12-2014, 03:28 AM   #547
KalEl63's Avatar
Yep it is, just really strange like I said it was only at most 1mm not even when I think about what I trimmed off.
1.21 GIGAWATTS!!!
Old 07-12-2014, 06:20 AM   #548
joecool's Avatar
The picture tebo just posted of his production ZX6 has a 2mm shim under the outside steering knuckle. It does have a ton of bump steer and this shim will reduce the amount.
Joe Cool
Old 07-12-2014, 06:20 AM   #549
joecool's Avatar
Default Bump steer
Joe Cool
Old 07-12-2014, 02:06 PM   #550
4WDriver's Avatar
Originally Posted by Andy p View Post
The hub carrier has a little bit more material top and bottom on the "6" the king pin screws sit in a recess top and bottom
nice. Thanks! Still have to shave the control arms to allow full steering lock and full droop?
4WDriver is offline   Reply With Quote
Old 07-12-2014, 04:08 PM   #551
joecool's Avatar
With the kit set up you will not need to shave the arms at all. I guess running more droop than the kit set up suggest will be unnecessary but if you do increase the droop the arms will need a dremel for clearance.
Joe Cool
Old 07-13-2014, 04:47 AM   #552
jelly's Avatar
thanks. missed that.
added the bump steer spacer. smooths out the steering nicely.
Old 07-13-2014, 05:52 AM   #553
gelshocker's Avatar
Do you have a KO servo to test? Sometimes the servo cases are too big?
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 07-13-2014, 09:38 PM   #554
Holmberg418's Avatar
Move the servo back. Use no shims. Or dremil a little off the mount to move the servo back. Or you can run rotate the servo horn on the other direction.
Kyosho America, Lunsford, Stickit1racing, Jconcepts, JTP
Full Throttle R/C Raceway www.ftrcr.com
510 Raceway
Holmberg418 is offline   Reply With Quote
Old 07-13-2014, 11:13 PM   #555
joecool's Avatar
I'm using a ko RSX2 response with no issues. I also have the mount with the 2mm spacer in between.
Joe Cool
