    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree9Likes
Old 07-07-2014, 10:13 PM   #526
Thanks & Thanks
Originally Posted by vikingen View Post
excellent choice
Originally Posted by K_King View Post
Response.
Order placed!
Kyosho RB6 + Team Orion + Vampire Racing
Kyosho ZX6 + Team Oron + KO ProPO
MR03 + PN Racing
MB010
KO Propo EX-1
Steady14 is offline   Reply With Quote
Old 07-07-2014, 11:34 PM   #527
vikingen's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Zylux View Post
Nice, almost exactly the layout I think I will use (even the same servo!). I think I will run the servo on the opposite side if this is an option though as the motor & esc will be heavier than my battery.
I'd be really interested to know the weight and if possible, weight distribution front / rear and left / right if you get a chance and find your scale.
Cheers,
Dom
1703g
vikingen is offline   Reply With Quote
Old 07-08-2014, 02:55 AM   #528
Zylux's Avatar
Originally Posted by Jpm1 View Post
Hi Dom, I swapped my servo over for better balance also, just swap the steering linkage over and cut the 2 little lugs of the plastic servo tray which allows you to reverse it.
Justin
Thanks Justin, I'll do the same.
Zylux is offline   Reply With Quote
Old 07-08-2014, 02:57 AM   #529
Zylux's Avatar
1703g
Thanks. I think with enough titanium etc we should be able to get it down closer to 1600.
What is the Roar legal weight limit for 4wd buggy? Anyone know if this applies in Australian racing?
Old 07-08-2014, 03:02 AM   #530
Jpm1's Avatar
1613 g is the minimum in oz, I think it's only enforced at sanctioned events, to drop weight I use alloy screws, they are a lot lighter then titanium but not as strong.
Justin
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 07-08-2014, 03:24 AM   #531
Zylux's Avatar
Justin
Yeah, I thought about alloy screws but I have enough instances where the heads of even steel screws round so am reluctant to try them. Especially given how tough the Kyosho plastic seems to be. I guess aluminium screws would be about 50% lighter than steel ones vs about 30% for titanium.
I emailed MIP about the possibility of some aluminium out-drives, dog-bones etc but was informed that they have no plans to make them for the ZX6 at this stage. Unless they got a lot of interest.... come on guys!
I'm actually thinking about trying to make my own alloy drive-train bits for some fun. Just need to get my hands on a Mill... have a lathe but almost everything seems to need at least one milling operation!
Old 07-08-2014, 05:42 AM   #532
Kyosho do light weight diff outdrives for the ZX5, diff parts are shared.
MIP do light weight shafts for the RB5/RB6 range, rear shafts shared.
Plenty of ways to get the weight out already BUT try it a as it is, unless your struggling for acceleration in stock classes then carrying a little extra weight low down only helps plant the car.
http://model-car-racer.co.uk/
Today AE .. tomorrow who knows?
RogerM is offline   Reply With Quote
Old 07-08-2014, 05:57 AM   #533
Zylux's Avatar
Great, thanks. I didn't realise the RB6 shafts were the same in the rear as the ZX6! Already ordered the light weight Kyosho diff out-drives.
People often say that extra weight can be good, but I'm just not a believer in "heavier is better" regardless of the conditions etc. I'll try it out as it is before I go too extreme though.
Cheers, Dom
Old 07-10-2014, 11:46 PM   #534
Jinggoy's Avatar
Tebo & his production ZX6!
jtprc.com - sorry can't post link new to RCtech
Jinggoy is offline   Reply With Quote
Old 07-11-2014, 02:14 PM   #535
4WDriver's Avatar
can anyone describe the difference between the ZX6 (LA371) and ZX5 FS2 (LA254) front knuckle and hub carrier parts?
Last edited by 4WDriver; 07-11-2014 at 03:02 PM. Reason: found photo of LA371 - says ZX5 on package
4WDriver is offline   Reply With Quote
Old 07-11-2014, 03:03 PM   #536
Andy p's Avatar
The hub carrier has a little bit more material top and bottom on the "6" the king pin screws sit in a recess top and bottom
A pic might explain it abit better
This is the "6"
This is the "5"
Andy p is offline   Reply With Quote
Old 07-11-2014, 03:56 PM   #537
ferrarieeeee's Avatar
Does anyone managed to break any part yet? Have made the pre-order and wondered what parts should I be keeping
Electric: eb48.3 / eb48sl / 811e / d413 / b5 / b5m / kr / pro2b / msc / scte
Nitro: nb48.3 / xb8
ferrarieeeee is offline   Reply With Quote
Old 07-11-2014, 05:15 PM   #538
biggerT's Avatar
Just front tower so far
Jesus saves Moses divides and Satan drives a stick
Kyosho rb6 kyosho rudebits db2 kyosho rudebits db4
biggerT is offline   Reply With Quote
Old 07-11-2014, 05:38 PM   #539
mourinho's Avatar
Trader Rating: 42 (100%+)
I started building my zx6 and being my first 4 wheeler I did something pretty stupid
I was looking at the arms and thought 'gee I dont like the look of those mould points' so I snipped them all off and ignorantly carried on until I reached roughly halfway and it was time to put on the swaybars...
Waiting for new arms to arrive, nice kit though.
mourinho is offline   Reply With Quote
Old 07-11-2014, 06:37 PM   #540
Trader Rating: 55 (100%+)
That's one beefy tower. Where did it break
Speedychris22 is offline   Reply With Quote
