    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 07-07-2014, 01:13 AM   #511
ferrarieeeee's Avatar
For a low/med bite track dirt track with lots of turns, use front or rear motor placement?
Electric: eb48.3 / eb48sl / 811e / d413 / b5 / b5m / kr / pro2b / msc / scte
Nitro: nb48.3 / xb8
ferrarieeeee is offline   Reply With Quote
Old 07-07-2014, 01:59 AM   #512
Jinggoy's Avatar
wow lots of plastic stuff, i hope Yaiba and Exotek will have some Red hopup for this kit.
Jinggoy is offline   Reply With Quote
Old 07-07-2014, 02:02 AM   #513
vikingen's Avatar
Trader Rating: 27 (100%+)
Finished, using my Proline bulldog shell straight off the zx5. Bit short.
vikingen is offline   Reply With Quote
Old 07-07-2014, 02:04 AM   #514
Zylux's Avatar
Originally Posted by JarrodP View Post
That is what the scales said. Sorry I don't have proper rc car scales.
No need to apologise mate. So I assume that the 1705g total is the most accurate; using only 1 scale. The front + rear measurements add up to 1774; probably something amiss there.
Zylux is offline   Reply With Quote
Old 07-07-2014, 02:43 AM   #515
Zylux's Avatar
Nice! Engine/electronics layout pics and weight?
Old 07-07-2014, 03:24 AM   #516
KalEl63's Avatar
Good to see another one finished
I got my DE wheels today and noticed the front wheels are about 2mm (give or take a fraction of a mm) narrower than the ZX6/ZX56 wheels and the offset different.
However his didn't do much to the overall front track.
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 07-07-2014, 06:37 AM   #517
JarrodP's Avatar
They were weighed separate.. I can't see why you would add them up.
Kyosho Inferno MP9e - Inferno ST-RR Evo ep - Ultima RB6 -Lazer ZX6 - Ultima SC6 - Ultima RT6
Tamiya XV-01 Rally
JarrodP is offline   Reply With Quote
Old 07-07-2014, 01:47 PM   #518
vikingen's Avatar
Need to balance and weigh, but dunno where the wife put the scales
wiring straight over from the zx5 for now. made it work without getting out the soldering iron
Old 07-07-2014, 02:54 PM   #519
Zylux's Avatar
Nice, almost exactly the layout I think I will use (even the same servo!). I think I will run the servo on the opposite side if this is an option though as the motor & esc will be heavier than my battery.
I'd be really interested to know the weight and if possible, weight distribution front / rear and left / right if you get a chance and find your scale.
Cheers,
Dom
Old 07-07-2014, 05:55 PM   #520
Trader Rating: 48 (100%+)
Any reports on how the car drives?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 07-07-2014, 06:17 PM   #521
Jpm1's Avatar
Cheers,
Dom
Hi Dom, I swapped my servo over for better balance also, just swap the steering linkage over and cut the 2 little lugs of the plastic servo tray which allows you to reverse it.
Justin
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 07-07-2014, 06:41 PM   #522
vikingen's Avatar
hoping to test it out this coming weekend. its winter here so its dark before I can get to a track after work
Old 07-07-2014, 08:02 PM   #523
Im just about to buy my servo for this, some advise and understanding of your options?
Full size or Low Profile?
Power or Response?
Looking at the KO Propo RSx one10?
Kyosho RB6 + Team Orion + Vampire Racing
Kyosho ZX6 + Team Oron + KO ProPO
MR03 + PN Racing
MB010
KO Propo EX-1
Steady14 is offline   Reply With Quote
Old 07-07-2014, 08:22 PM   #524
vikingen's Avatar
excellent choice
Old 07-07-2014, 08:22 PM   #525
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Response.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
