    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 07-04-2014, 02:58 PM   #481
Originally Posted by Holmberg418 View Post
Yes. Gear diffs are available for the car from kyosho
Have they made some new gear diffs or it is from the ZX5?
Magnus F is offline   Reply With Quote
Old 07-04-2014, 05:16 PM   #482
Trader Rating: 42 (100%+)
Do the plastic ring gears hold up?
Do they make a Metal option?
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 07-04-2014, 08:27 PM   #483
Trader Rating: 48 (100%+)
This Will be my first wheeler with ball diffs. How tight do I have to make them? Also go I set the front or tighter then the other ?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 07-04-2014, 09:13 PM   #484
Holmberg418's Avatar
With the zx5 we normally ran the front looser then the rearm but this car might be different. And yes they have diffs made for this car. And the plastic gears hold up if you shine the diffs correct. I believe it's the same diff and parts at the zx5.
Kyosho America, Lunsford, Stickit1racing, Jconcepts, JTP
Full Throttle R/C Raceway www.ftrcr.com
510 Raceway
Holmberg418 is offline   Reply With Quote
Old 07-05-2014, 03:36 AM   #485
vikingen's Avatar
Trader Rating: 27 (100%+)
finally started the build. all as expected from a k-car kit.
vikingen is offline   Reply With Quote
Old 07-05-2014, 04:13 AM   #486
KalEl63's Avatar
Couldn't agree more vikingen
Here are my last two pics (couldn't wait for the black DE Wheels to arrive before posting) Plus a pic of my car rack with one spot to go for all to be full with 6'ers
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 07-05-2014, 05:13 AM   #487
mog ruith's Avatar
envy you kalel rack full of 6ers. does the zx6 accept a full stick pack? it look like it doesnt but im asking out of curiosity.
mog ruith is offline   Reply With Quote
Old 07-05-2014, 05:51 AM   #488
Jpm1's Avatar
Here is a pic of mine, using the prototype SMC speedy and new 3500/70c lightweight SMC shorty, I moved the servo to the other side for better balance
Justin
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 07-05-2014, 12:23 PM   #489
When will they be available?
Old 07-05-2014, 01:24 PM   #490
Who knows? The car is not even out yet in the states.
My Credit Card
Old 07-05-2014, 02:16 PM   #491
I suggest you buy one and come to the track with it, just so I can drool on it
"If you have complete control over the damned thing, you're not going fast enough."
kaan is offline   Reply With Quote
Old 07-05-2014, 02:18 PM   #492
Good point!:-)
Old 07-05-2014, 03:25 PM   #493
KalEl63's Avatar
I am very lucky to have them all and the full size battery won't fit either
1.21 GIGAWATTS!!!
Old 07-05-2014, 04:01 PM   #494
Zylux's Avatar
Justin
Hmm, looks porky. Without a 3500mAh battery it looks like it will be hard / impossible to achieve min weight.
Zylux is offline   Reply With Quote
Old 07-05-2014, 08:49 PM   #495
When the car is available!
510 Raceway
