    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 07-01-2014, 06:26 PM   #451
Trader Rating: 48 (100%+)
Originally Posted by JarrodP View Post
Great pics mate.
Yeah, keep them coming! In the US we have to wait for another 3 weeks
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 07-01-2014, 08:29 PM   #452
vikingen's Avatar
Trader Rating: 27 (100%+)
not if you shoot ProShop an email
vikingen is offline   Reply With Quote
Old 07-02-2014, 12:58 AM   #453
Can you please give a link to which RCPROSHOP you are referring to?
Kyosho RB6 + Team Orion + Vampire Racing
Kyosho ZX6 + Team Oron + KO ProPO
MR03 + PN Racing
MB010
KO Propo EX-1
Steady14 is offline   Reply With Quote
Old 07-02-2014, 01:00 AM   #454
Hay guys what shock piston and oil are you guys going to use to start with
Brought to you by the number 4 and the letter X
Running a Kyo MP9 TKI3 and An STRR EVO truck
rcmad2700 is offline   Reply With Quote
Old 07-02-2014, 02:02 AM   #455
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
I would guess it'll probably be close to the same as the ZX5 maybe. Which for me is 1.4x3 flat front and 1.6x2 tapered rear. Oils for me are 35 front and 32.5 rear at the moment. Just a guess though.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 07-02-2014, 03:09 AM   #456
vikingen's Avatar
http://www.pro-s-futaba.co.jp/home/a...customers.html
you will need to email them. keep your English basic and clear, advising what you want, how many of that item and where postage is required to.
they will quote you a price in yen, then when you agree they'll send you a PayPal payment request
Tokyo to Sydney Australia via EMS takes 2-3 days door to door including local customs/useless mailmen.. to give you an idea of their postage efficiency.
Old 07-02-2014, 04:48 AM   #457
79kmc's Avatar
Default spur gears
Hey guys i just picked up my zx6 just wondering if you can use ae spur gears
Kyosho rb6 Tekin Rs-17.5 tekin
Kyosho zx6 Tekin Gen2 Spec-17.5 tekin
www.Coast2Coastrc.com
79kmc is offline   Reply With Quote
Old 07-02-2014, 05:02 AM   #458
KalEl63's Avatar
OK I have some more build pics.
These are not as detailed tonight as I was limited with my build time and wanted to get to a certain point.
I knew the ball diffs were going to take me a while to do. Plus I was looking thru my SC6 that I have to build too
(also not sure I want to load the thread up with a heap of pics)
I have one tip so far when building don’t screw the wing mounts in until after you screw down the 4 screws when mounting it to the rear diff case.
The wing mounts cause you to have to the driver on a slight angle so not the best when screwing into new plastic.
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 07-02-2014, 05:14 AM   #459
Legend, thanks!
MR03 + PN Racing
MB010
KO Propo EX-1
Old 07-02-2014, 05:21 AM   #460
Great job Dave looks good
My Credit Card
Old 07-02-2014, 05:33 AM   #461
shoman24v's Avatar
Trader Rating: 14 (100%+)
Looking great.
Is this the best buggy you can by? My last Kyosho was an Ultima ST. Also, how are the hop-ups for this vehicle?
| HPI Blitz ESE | Reedy Mach 2 9.5 |Schumacher Cougar SV2 | (2) Team Associated RC10T | Shelfer/Runner | (2) Team Associated RC10T2 Shelfer/Runner | Team Losi XX & XX-T & XX-T CR Graphite Plus Shelfers | Team Losi XXX-4 Shelfer |
shoman24v is offline   Reply With Quote
Old 07-02-2014, 06:10 AM   #462
KalEl63's Avatar
Cheers for the likes with the pics
I will try and do more tomorrow night but have be careful as the wife might file a missing person with me building this then the SC6
If anyone can enlighten me on what rear toe the kit has with D in/D out and also what rear anti-squat it may have would be cool.
I'm guessing 3 degree rear toe and ~1.5 anti-squat
1.21 GIGAWATTS!!!
Old 07-02-2014, 09:26 AM   #463
joecool's Avatar
Trader Rating: 19 (100%+)
Are the steering knuckles going to rub on the front arms like they did on the zx5? When we ran more droop in the front end of the zx5 a dremel was needed shave the arm slightly for clearance to turn the wheels full lock. I hated that about the old car.
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 07-02-2014, 01:56 PM   #464
Zylux's Avatar
I was going to order a new steering servo for this buggy and having only had an RB6 2WD I'm not sure if I need a full-size servo for a 4WD or if a shorty will cut it?
I use a KO Propo RSX one10 Response in the RB6 and it's great. Would use the same servo in the ZX6 if I could as it's lighter than a regular size servo and would allow me to swap between cars if needed. But does the 4WD put a LOT more stress on the steering servo? Should I be buying a beefier servo?
Zylux is offline   Reply With Quote
Old 07-02-2014, 01:58 PM   #465
Zylux's Avatar
If the rear suspension blocks are like the optional RB6 ones then D in/D out would be 6 degrees of Toe. D in/ D in would be 3deg as would D out/ D out.
