Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 01-11-2017, 05:10 AM
  #2056
Remember that the bevel gears will push each other apart as they load up.
RogerM is offline
Old 01-11-2017, 05:14 AM
  #2057
kenny lutz's Avatar
Trader Rating: 38 (100%+)
The diff itself feels good just the front and the rear have a little tightness but I'm just going to let the gears wear and mesh together and see what we have after a pack or two
kenny lutz is offline
Old 01-15-2017, 09:58 AM
  #2058
SAMCRO's Avatar
Originally Posted by vikingen
anyone destroying 6.6 spurs ? mesh is right yet some flex seems to be happening out on the track and its putting flat spots on my spurs in less than a battery's run
Yes, I have destroyed two. Can't even get one run in on the car. The center diff quality is terrible
SAMCRO is offline
Old 01-15-2017, 03:20 PM
  #2059
vikingen's Avatar
Trader Rating: 29 (100%+)
it tends to be in one spot on the spur, which would indicate a random moment of tight mesh/flex. not sure how its happening with the 'HD' chassis.
as pictured on the previous page, im now running a top deck. yet to test it though.
vikingen is offline
Old 01-15-2017, 08:11 PM
  #2060
likea45's Avatar
Weird I have a mod zx6 and a 13.5 zx6 and haven't had any issues with spurs. I do take my sweet time to get the mesh perfect though.
likea45 is offline
Old 01-15-2017, 11:03 PM
  #2061
vikingen's Avatar
Never had an issue with my zx6, only now with the zx6.6. Different spur gear obviously
vikingen is offline
Old 01-15-2017, 11:11 PM
  #2062
JsK
R/C Tech Elite Member
JsK's Avatar
Put on a pinion one tooth bigger than you want. Push the mesh up firm and
tighten the mount screws. Loosen the setscrew on the pinion and slide it off
and then install the one tooth smaller. That's about as tight a mesh as you can
with 48p.
JsK is offline
Old 01-16-2017, 05:14 AM
  #2063
Do you have any vertical movement on the centre diff / slipper assembly when everything screwed up?
If so you can run a small grub screw down each hole in the top cap to JUST touch the bearing, that will stop that.
My ZX6 has a lot of running on it and is still perfect but my previous ZX5FS2sp needed the grub screws to prevent this movement.
I've put at least 50 packs through my centre diff and all teeth perfect.
RogerM is offline
Old 01-16-2017, 01:27 PM
  #2064
vikingen's Avatar
zero vertical movement. its really quite odd. gonna try it with the top deck.
vikingen is offline
Old 01-16-2017, 03:39 PM
  #2065
SAMCRO's Avatar
I Am running 300k center diff fluid like tebos setup sheet calls for. Could that be part of it? Too much force on the spur gear to turn it over?
I might try 100k diff fluid
SAMCRO is offline
Old 01-16-2017, 03:42 PM
  #2066
vikingen's Avatar
im running 500k.. maybe thats it !
vikingen is offline
Old 01-16-2017, 04:02 PM
  #2067
tel
If you guys are running gear diffs and heavy center diff fluid you'll probably need to be careful about landing on power. If both the front and rear tires have great traction on landing a jump and you're on throttle that power has to go somewhere. When running a slipper you could withstand that easily but with a center diff you on have a few plastic teeth on the spur to absorb all that kinetic energy.
tel is offline
Old 01-16-2017, 04:26 PM
  #2068
vikingen's Avatar
edit : getting some 200,000cst and 300,000cst methinks
vikingen is offline
Old 01-16-2017, 09:10 PM
  #2069
likea45's Avatar
Should have been more clear they are both 6.6s running the CD with no spur issues but like I said I take my time on the mesh. It isn't as easy with the mount the way it is as it wants to move when tightening the top screw.
likea45 is offline
Old 01-17-2017, 04:55 AM
  #2070
I've run up to 1.5mil CST on dry astro & carpet with no issue other than a slipepr definitely being faster.
300k-500k on wet astro.
RogerM is offline
