Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
#2042
with the VVC Diff Shaft.
You can do the same in the center diff.
Pic :
#2044
Replace the diff Shaft in LAW50 http://www.kyoshoamerica.com/Gear-Di...6_p_23486.html
Pic :
Pic :
#2046
http://www.avidrc.com/product/5/acce...cessories.html
#2047
Anyone run this buggy with a 13.5? Looking for starting gearing recommendations.
#2048
anyone destroying 6.6 spurs ? mesh is right yet some flex seems to be happening out on the track and its putting flat spots on my spurs in less than a battery's run
#2050
This may seem silly but double check that all your screws are tight on the bottom bulkheads, particularly the aluminum bits. I've had them loosen up and as a result cause the mesh to be out of wack.
#2053
anyways, Tebo's top decks don't seem to be available, so I've gone with Bezerk once again. HD stiff top deck. Had been running Bezerk's flex top deck in my ZX6 which was great for low-med grip
#2054
Amain has Protek titanium screw kit:
https://www.amainhobbies.com/protek-...t-2069/p388125
Or there is always Lunsford.
http://www.lunsfordracing.com/mm5/me...e=CARS-KYLZX66
For bearings you can't beat AvidRC. You can pick and choose or get a ZX5 kit.
http://avidrc.com/flexkit/?kit=217&kitname=ZX5
