Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 01-03-2017, 08:11 PM
  #2026
jag5508's Avatar
Trader Rating: 15 (100%+)
I have the heavy duty chassis that came with drive shafts . Do those work with the center gear diff ?
jag5508 is online now
Old 01-04-2017, 07:21 AM
  #2027
yes
scoobyrs25 is offline
Old 01-04-2017, 06:59 PM
  #2028
kenny lutz's Avatar
Trader Rating: 38 (100%+)
Just bought a new zx6 and I'm trying to figure out if these work with the gear doff outdrives or if you have to buy the other out drives? I take it these are like mip pucks? If so has anyone tried them and are they worth it?
VVC Blades TFW126
kenny lutz is offline
Old 01-05-2017, 07:10 AM
  #2029
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Those are the ones for the gear diff's.
I just installed the ball diff version in my son's car but we haven't had it on the track yet.
Kraig is offline
Old 01-05-2017, 07:20 AM
  #2030
kenny lutz's Avatar
Ok next question is build it front or rear motor? Med-high bite clay. Going to do some 13.5 wheeler and mod stuff with the car.
Old 01-05-2017, 08:06 AM
  #2031
tobamiester's Avatar
Trader Rating: 360 (100%+)
VVC Blades TFW126
Yes I run the VVC blades all the time. Very smooth, zero wear. Just keep an eye on the blades and replace if look worn.
Its your choice on motor location. Tuning option.
Rear motor is more 'traditional' and I think better suited to lower grip surfaces. Its more aggressive but can wheelie a bit...
Front motor is smoother and a higher bite surface option. Thats my opinion based on experience, not fact. I personally prefer front motor as its a little calmer and I didn't like how the car wanted to wheelie when I grabbed a handful of throttle .
My car is 47%/53% weight bias with Front motor.
tobamiester is offline
Old 01-05-2017, 11:49 AM
  #2032
kenny lutz's Avatar
Thanks for the info and I think I'm going to do front motor just need to figure out where to mount a fan
Old 01-05-2017, 11:57 AM
  #2033
kenny lutz's Avatar
Anyone know who has these parts in the us?
VVC Blades TFW126
Old 01-05-2017, 12:27 PM
  #2034
VVC Blades TFW126
http://www.kyoshoamerica.com/VVC-Cup...r_p_24081.html
http://www.kyoshoamerica.com/C-Joint...ON_p_4558.html
Old 01-05-2017, 02:27 PM
  #2035
kenny lutz's Avatar
How do those work the other ones have a shaft on the back to do through the diff housing? Maybe for the center shafts?
Old 01-05-2017, 03:36 PM
  #2036
direct drop-in replacement for stock gear-diff drive cups.
Old 01-05-2017, 03:47 PM
  #2037
I made a custom mount. As I put the floating servo mount had spare stock plastic servo mounts. put long screws thru a fan into the servo mounts and screwed to chassis thru existing holes:
Old 01-05-2017, 05:16 PM
  #2038
kenny lutz's Avatar
30mm and what diff fluids you running
Old 01-05-2017, 05:24 PM
  #2039
kenny lutz's Avatar
That's what the stock ones look like so idk how those are a direct replacement? Looks like they might be for the center shafts to me.
Old 01-05-2017, 05:27 PM
  #2040
dmcguire's Avatar
Kenny, those are the diff outdrives that the axle dogbones fit in. The parts referenced above go on the diff's pinion gear for the center driveshafts.
dmcguire is offline
