    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 12-12-2016, 10:38 PM   #1996
likea45's Avatar
Originally Posted by ProfessorX View Post
Do I need the HD chassis too or it works on the stock chassis also ???
Should work on stock chassis
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 12-14-2016, 09:33 AM   #1997
skrichter's Avatar
Send a message via AIM to skrichter
I think I found the anti-squat chart that should correlate to the the ZX6. I threw out the question to Tebo, and he wasn't entirely sure off hand.
However, I'm assuming this chart transfers over from the ZX5 to the ZX6, since the same shims and tranny cases are used.
http://site.petitrc.com/setup/kyosho...SquatChart.pdf
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is online now   Reply With Quote
Old 12-17-2016, 05:33 PM   #1998
tobamiester's Avatar
Trader Rating: 277 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Some impressive weight savings with the VVC Joints.
Stock outdrives:
VVC Outdrives
tobamiester is offline   Reply With Quote
Old 12-18-2016, 03:10 PM   #1999
Suspended
Stock outdrives:
VVC Outdrives
Whats the part number for those vvc out drives?
chriso138 is offline   Reply With Quote
Old 12-18-2016, 03:20 PM   #2000
Suspended
Is anyone else having issues with the center diff leaking?
Also, am I doing something wrong or is there an easier way to get the center diff out without having to take the diff housing apart and pull the center drive shafts?
Old 12-18-2016, 03:33 PM   #2001
TFW126
Old 12-18-2016, 03:34 PM   #2002
Suspended
TFW126
Thanks!
Old 12-18-2016, 09:27 PM   #2003
likea45's Avatar
It does leak a bit. I will say when I ran an X-ray it was actually worse. Oil tends to flush from the screws, it's fairly common on a lot of CDs. The only real way to access the CD is by removing the screws underneath on the bulkheads and then pulling it off the chassis.
Old 12-19-2016, 04:56 PM   #2004
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
It seems the front arms are only sold as a single front and a single rear, but the rear arms are still the older FS2 style arms. Can I get a spare set of front arms for my new ZX6.6 by themselves? Happy Holidays All!
https://www.amainhobbies.com/kyosho-...ola272/p221424
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 12-19-2016, 04:59 PM   #2005
13Maschine's Avatar
Thanks Tobameister for the VVC outdrive tip. Those look dope!
Old 12-19-2016, 05:40 PM   #2006
Thanks!
Spare blades TFW001-01
Old 12-20-2016, 01:19 PM   #2007
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
I'm looking for a zx6.6 with gear diffs. Inbox me if you have something
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 12-21-2016, 07:41 PM   #2008
teeforb's Avatar
Any setup sheets for the zx6.6 besides tebo setup?
Old 12-24-2016, 05:50 AM   #2009
When changing over to front and rear diffs (LAW50), do you need to change the bevel gear (LA372) to steel? Don't remember if there is a solid shaft with the bevel gear to replace the stock parts. If so what is the part number, can't find it.
Turbo911 is offline   Reply With Quote
Old 12-24-2016, 07:32 AM   #2010
Yes. http://www.kyoshoamerica.com/Drive-B...6_p_23437.html
