    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 11-09-2016, 12:42 AM   #1936
Ive noticed on a number of set ups, that people are playing with the inserts on the front hinge pin holders to achieve toe in inboard rather than through the steering turnbuckles?
What have people found by doing this?
njc11 is offline   Reply With Quote
Old 11-09-2016, 02:55 AM   #1937
tef
I think for me this setting did two things;
1) I don't like the bump steer or steering angle during the stroke of the shock while turning. This for me helped smooth out the feel of the front through the turn
2) initial scrub of when the front takes the weight off power. The slight angle in my testing resists the weight transfer slightly to make it easier to drive. This is most noticeable on turf and carpet
3) I'm insane?
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 11-09-2016, 08:35 AM   #1938
Thanks for the response :-)
Old 11-09-2016, 06:40 PM   #1939
RandyB's Avatar
I ordered my lazer 6.6 today. I was told Kyosho America will have them in stock november 16th.
Any suggestion on what I should get with it? option parts? running on high and med bite clay
RandyB is offline   Reply With Quote
Old 11-10-2016, 06:28 AM   #1940
tobamiester's Avatar
Trader Rating: 277 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
I'll build mine with Gear Diffs.
Alum zero degree hubs.
Lundsford Titanium Rods/Cups (not because I think they're needed but love the quality and feel)
tobamiester is online now   Reply With Quote
Old 11-10-2016, 09:47 PM   #1941
likea45's Avatar
The center gear dif in this car is a pleasure to drive. I started at 100k and felt the car was very controlled and showed smoother power delivery at initial throttle and took the edge off of aggressive braking. Recommend it highly.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 11-14-2016, 03:04 PM   #1942
RandyB's Avatar
What diff fluid does the 6.6 come with?
Old 11-14-2016, 09:54 PM   #1943
likea45's Avatar
It doesn't.
Old 11-15-2016, 12:48 PM   #1944
RandyB's Avatar
Originally Posted by likea45 View Post
It doesn't.
for the center diff?
Old 11-16-2016, 12:34 PM   #1945
RE: RandyB
From what I can determine after reading through the ZX6.6 assembly manual. The recommended range is 100k to 500k CST. From the setup sheets from Jared Tebo from past Reedy Race(s) he was running 100k and 300k. Kyosho has 100k, 300k, 500k and they just added 1M CST to their product line.
Also the center gear diff kits are showing available as of last night on Kyosho America's web site. I'd expect parts to also being stocked this week.
-Steve C.
dbartisan is offline   Reply With Quote
Old 11-16-2016, 12:57 PM   #1946
Center Diff (and all the new 6.6 parts listed in Wiki) are available via Kyosho America btw.
Old 11-16-2016, 10:53 PM   #1947
likea45's Avatar
Like shock oil you provide your own.
Old 11-17-2016, 12:22 PM   #1948
Default 6.6 in stock
6.6 is in stock at kyosho America.
Old 11-17-2016, 02:48 PM   #1949
Trader Rating: 131 (100%+)
finally got all the parts for the center gear diff from the UK today and installed this afternoon without any issues in the zx6
skyline1015 is offline   Reply With Quote
Old 11-17-2016, 03:36 PM   #1950
Trader Rating: 32 (100%+)
http://www.losipartshouse.com/Kyosho.../kyo30047b.htm
raved007 is offline   Reply With Quote
