    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree9Likes
Old 11-06-2016, 05:58 PM   #1921
vikingen's Avatar
Trader Rating: 27 (100%+)
vikingen is offline   Reply With Quote
Old 11-06-2016, 09:50 PM   #1922
likea45's Avatar
Originally Posted by vikingen View Post
I saw the full kit was there, that's where my center dif is coming from. I decided to wait for the car to hit the US as I can get it cheaper. Post build pics!!
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 11-07-2016, 06:00 AM   #1923
masterhit's Avatar
Trader Rating: 15 (100%+)
Manual is up!
masterhit is offline   Reply With Quote
Old 11-07-2016, 07:33 AM   #1924
tobamiester's Avatar
Trader Rating: 281 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Originally Posted by masterhit View Post
Awesome thanks! I was just checking last night! (Updated Wiki).
tobamiester is offline   Reply With Quote
Old 11-07-2016, 03:14 PM   #1925
exheliguy's Avatar
I'm so jealous. I'm just waiting for you pre-order. What electronics are going in it? Are you keeping in the front and rear ball diffs?
Futaba, kyosho, Reds, Hitec, Aka,VP Pro , Tekin
exheliguy is offline   Reply With Quote
Old 11-07-2016, 03:19 PM   #1926
exheliguy's Avatar
The balls that come with the kit are made of what? Steel or ceramic?
Old 11-07-2016, 04:31 PM   #1927
vikingen's Avatar
no plans to start the build yet. this time of year gets so busy and im not even sure I'll get to a meet during whats left of 2016.
will be LRP esc/motor and KO servo. I've got some brand new gear diffs there ive not put in my ZX6, so planning on gear diffs throughout for the 6.6.
Old 11-07-2016, 09:09 PM   #1928
tef
Originally Posted by likea45 View Post
I'm planning to give the gear difs a shot. What's good front and rear on medium bite clay?
This is what I'm running on med bite tracks.
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 11-07-2016, 11:31 PM   #1929
likea45's Avatar
I'll give it a shot! Thanks.
Old 11-08-2016, 04:54 AM   #1930
tef
Just an FYI the biggest contributing factor on this car is the sway bars. The chassis is narrow so it's easily influenced and can feel inconsistent causing the rear to over turn or "wiggle" on exit. I run thick bars to stop that. I'm only pointing this out because I thought it originally was the gear diffs causing the problem and it wasn't. Give them a shot or try this setup completely and I think you will be pleased.
Thick bars also allow for lighter shocks. This is just my opinion on the testing I did. To each is own
Old 11-08-2016, 08:34 AM   #1931
johnny t's Avatar
what does "no carbon strap" in the comments mean?
johnny t is offline   Reply With Quote
Old 11-08-2016, 09:01 AM   #1932
Trader Rating: 133 (100%+)
so i recently picked up a brand new zx6 for cheap and looking to get the center diff installed. i already installed the HD chassis and ordered the required parts for the center diff from overseas. other than the required parts, should there be an issue with installing the center diff?
here are the parts that where ordered
1 x #K.LA379 - KYOSHO JOINT CUP COVER LAZER ZX606
1 x #K.LA375-78 - KYOSHO MAIN GEAR (78T-48DP) LAZER ZX6.6
1 x #K.LA359B - KYOSHO CENTRE MOUNT LAZER ZX6.6
1 x #K.LA378 - KYOSHO CENTRE SHAFT (88) LAZER ZX6.6
1 x #K.LA377 - KYOSHO CENTRE SHAFT (79.5) LAZER ZX6.6
1 x #K.LA376 - KYOSHO CENTRE SHAFT (71.5) LAZER ZX6.6
1 x #K.LA375 - KYOSHO CENTRE DIFFERENTIAL GEAR SET LAZER ZX6.6
skyline1015 is offline   Reply With Quote
Old 11-08-2016, 10:58 AM   #1933
tef
Sorry, I attached a pic. The strap that lays flat on the chassis in the pink box. I removed it. Helps the rear make traction.
Old 11-08-2016, 01:41 PM   #1934
johnny t's Avatar
Ok, so the chassis stiffener/plate/thingy. Thanks. Do you find it loosens the zx6 on corner entry and tighten up on exit? Usually thats the rule with rear chassis flex, but not all cars designs react the same way.
Going to try your setup, i am a fan of using swaybars anyway. Even in 2wheel.
Old 11-08-2016, 05:08 PM   #1935
tef
It gets in easier yes off power and tightens it up on exit, correct
