    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 11-01-2016, 10:27 AM   #1891
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by exheliguy View Post
I see that kyosho makes aluminum rear hubs. Do they also make front knuckles and carriers? And will the zx6 parts fit the new 6.6?
If you buy parts for the ZX6, they will work on the ZX6.6. I honestly can't think of any that will not work.
I have not had any problems with the kit balls either.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-01-2016, 10:32 AM   #1892
JsK
JsK's Avatar
Lol thats funny i thought he meant the RB6.6 . So yeah anything for a zx6 should work on a
Zx6.6
JsK is offline   Reply With Quote
Old 11-01-2016, 02:24 PM   #1893
Originally Posted by likea45 View Post
I was running X-ray before coming to kyosho. The Xb4 is a very fast and capable platform. Two places I think the ZX6 excels at over the X-ray:
1. Cornering. My XB4 was very easy to drive right out of the box but I always felt like I wanted more steering. I'd find it but then I would have too much. I'd play with dialing it back and forth until I'd reach a point I could "live with". Spending an additional $100+ on the ECS drive shafts was the only way to get the car to turn the way I wanted. The ZX6 from go had loads of steering, too much in fact, but I found it much easier to dial back. With all that said the ZX6 enters and exits corners faster and is a bit more agile in tricky sections for my taste.
2. Jumping and landing. I was never blown away by the X-ray shock package. I had to buy aftermarket parts to keep them going although I will say they are easy to build. Nothing and I mean nothing touches a Kyosho shock though. Buttery smooth and plush, rebuild after rebuild after rebuild. They just have it down when it comes to shocks. This allows the car to land more plush and stable which in turn means quicker to accelerate on landing.
The XB4 is great chassis, I think it's durability is something Kyosho could learn from and it's easy to drive out of the box and a breeze to work on. The ZX6 is also easy to drive out of the box but I think it's better in the hands of an experienced driver who's had a wheeler before than a first timer. I believe the X-ray is easier for a beginner especially when durability is a factor.
I was instantly faster with the ZX6.
this is odd to me i found the xray to be the best steering buggy by a long shot.
dont get me wrong the kyosho is a great car, but i would definitely argue against your point that the kyosho has better steering - that was probably a personal setup issue. same with the speed issue. im faster with the xray than any other buggy but i have it dialed in.
i think the xray is way more versatile and more tune able especially with the different plastics and that's what makes it great to me. i can dial it in to my liking and it respond very well.
i do agree that kyosho's shocks are slightly better, but i don't think that comes into play honestly. they just dont get as dirty as quickly, but replace xrays o-rings with some kyosho or yokomo x-rings and it's on par, if not close enough to never ever tell a difference on the track.
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 11-01-2016, 03:57 PM   #1894
exheliguy's Avatar
Awesome, thanks guys. Just waiting on my hobby shop to get my zx6.6 now. Does the kit come with diff oil and shock oil? Asking because I just finished with a STRR Evo2 and it didn't include any fluids.
exheliguy is offline   Reply With Quote
Old 11-02-2016, 12:36 AM   #1895
vikingen's Avatar
Trader Rating: 27 (100%+)
My ZX6.6 ships from Japan today
vikingen is offline   Reply With Quote
Old 11-02-2016, 09:34 AM   #1896
Default Lazer ZX6.6 Center Diff parts list have been listed on Kyosho America's web site...
Consolidated from Kyosho America's web site:
LA375 - Center Diff. Gear Set(ZX6.6)
Center gear diff set for Lazer ZX6.6. Requires additional parts to install on ZX6. (LA359B,LA376,LA377 or LA378, and LA379.)
LA359B - Center Mount Set (ZX6.6)
Revised ZX6 upper plate for use with the center differential on the ZX6.6.
LA377 - Center Drive Shaft (79.5/ZX6.6)
Center driveshaft for Lazer ZX6.6. Used for front and rear when using rearward motor mounting positon.
LA379 - Joint Cup Cover (ZX6/ZX6.6)
Joint cup covers for Lazer ZX6.6 center diff.
LA376 - Center Drive Shaft (71.5/ZX6.6)
Front center driveshaft for Lazer ZX6.6 when using center diff and forward mounted motor.
LA378 - Center Drive Shaft (88/ZX6.6)
88mm Center driveshaft for Lazer ZX6.6. Rear center when using center diff with forward mounted motor position.
dbartisan is offline   Reply With Quote
Old 11-02-2016, 10:26 AM   #1897
tobamiester's Avatar
Trader Rating: 274 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Added above parts and created a Wiki.
tobamiester is offline   Reply With Quote
Old 11-02-2016, 10:28 PM   #1898
likea45's Avatar
That's cool. That's why we have different cars for different people. I know how to setup my cars, the X-ray wasn't slow by any means, but I found the ZX6 more to my liking.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 11-03-2016, 06:48 AM   #1899
JAE
Trader Rating: 26 (100%+)
Which has more rear grip and side bite on medium bite?
JAE is offline   Reply With Quote
Old 11-03-2016, 11:21 AM   #1900
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Smile
Gotta disagree here. Kyosho shocks are the best hands down, of any shock I've built so far. I've built AE, HB, Yokomo, Durango, KYO, pretty much all of them. Xray pistons have an insane amount of blow by, in comparison. Unfortunately the machined piston sets available via aftermarket like Avid or Schelle are designed to be very close to the originals, so same problem. Highly difficult to tune this way. Generally requires higher viscosity oil.
Changing the O rings will only decrease stiction, while this is useful, it still doesn't solve the blow by problem.
Shocks are a critical part of the the cars performance and this is noticeable and obvious on the track.
I haven't even mentioned the spring problem either.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 11-03-2016, 01:53 PM   #1901
the schelle and avid pistons do not have a lot of blowby on the xray shocks (I have 3 xray cars and have inspected intimately). If the avid/schelle pistons were any tighter in the bodies there would be too much friction to allow them to slide properly - they're as tight as any machined piston shock package. kyoshos are def the smoothest and most sealed shocks on the market - but in reality they don't make a big difference on the track - barely noticeable at best. still doesn't translate into more speed either.
the xray shocks are fantastic once you get the machined pistons in them and either some new o-rings or yokomo or kyosho x-rings. i would say that they're right there with TLR which I consider very good shocks, just above AE. Kyosho's do have the best seal, the smoothest action, but again the affects are minimal.
Old 11-03-2016, 02:12 PM   #1902
JAE
I have had 3 xray's in the last 6 months. I like their cars. I don't like their shocks. The Kyosho shocks are the best thing that's happened to me since the birth of my second child.
JAE
Old 11-03-2016, 02:19 PM   #1903
LOL - f the first child tho right?
but did you try avid pistons and kyosho x-rings? like i said after that they're right up there with TLR IMO.
Kyosho is the best i agree - but does it really translate on the track? not really. feels better when you build them and you change oil less is about it.
Old 11-03-2016, 02:29 PM   #1904
13Maschine's Avatar
Smile
I've tried Xrings and Avid and Schelle pistons in my shocks. I still have them and if the car doesn't sell soon I will get it out to measure with my micrometers.
Better shocks will always translate. Otherwise why would you upgrade to Avid or Schelle pistons on your Xray ? Why not just leave them stock if it doesn't matter?
Old 11-03-2016, 02:31 PM   #1905
13Maschine's Avatar
for the sake of reference experience.....I haven't built the latest version of TLR shocks, not since the XXX days. I know a lot of guys really like them.
@JAE: FIRST BORN SON! hahahahhaha
