    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 06-21-2016, 09:01 AM   #1831
do you punch holes in carpet tires?
gearit is offline   Reply With Quote
Old 06-21-2016, 09:27 AM   #1832
JsK
JsK's Avatar
So long as there is holes in the rim then no you don't punch the tire. There never gonna see water or dirt so you don't need holes to fling out water and debris.
JsK is offline   Reply With Quote
Old 06-21-2016, 10:28 AM   #1833
Trader Rating: 24 (100%+)
Originally Posted by ProfessorX View Post
Has anyone tried the Jared tebo reedy race set up in med to high clay. ????
Little late but I tried it on med clay and it seemed OK. Car is usually better than the driver in my case though!
fenton06 is offline   Reply With Quote
Old 06-21-2016, 05:39 PM   #1834
Old 06-30-2016, 02:07 AM   #1835
Default Servo on the right side
Hello,
I bought a used Zx6, I'd like to move the servo on the right side (the side of the battery in rear motor config), but the LA374 used to hold the servo on the left side of the car does not fit the chassis holes in the right side.
Do I need a different LA374? On ebay/amain seems there's only 1 LA374
Any help is appreciated
Kigne
Kigne is offline   Reply With Quote
Old 06-30-2016, 04:09 PM   #1836
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I didn't use the servo mount plate when I installed the servo on the right side of the car.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 07-02-2016, 01:30 PM   #1837
Default diffs
I changed to gear DIFF from ball and I have lost power, do I need to change center gear?
Old 07-02-2016, 02:58 PM   #1838
Super Moderator
Kraig's Avatar
Your internal ratio didn't change. Something else might be funny. What fluid did you build your gear diff with?
Old 07-02-2016, 04:03 PM   #1839
dmcguire's Avatar
Trader Rating: 21 (100%+)
Also, make sure the gear mesh is right on the ring and pinion. Not a bad idea to grease the gears as well. When I switched to gear diffs in my zx5, it sounded like a tractor, was slow and the motor got hotter than normal. Grease fixed all those problems for me.
dmcguire is offline   Reply With Quote
Old 07-02-2016, 05:08 PM   #1840
I used 5000 but found the problem, the sensor wire to the esc pulled out. Als does anyone have a base setup for the zx6 on carpet?
Old 07-04-2016, 10:07 AM   #1841
I used Tebo's World's setup with good success.
Old 07-17-2016, 10:00 AM   #1842
any info on the center diff. It been months on top of months and still nothing. Are they going to just wait and put it out with the next zx (whenever that is) Either way I find it a BIG LACK OF SUPPORT by kyosho not to have released one by now. Every other company has including small companies like hobby pro, caster, Durango, and even intech. just nuts to me that kyosho has dropped the ball this long and hasnt picked it up.
Some of you will say a center diff isnt needed but the fact is that it should be atleast an optional part.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 07-17-2016, 03:29 PM   #1843
Does anyone know if the zx6 front wheels will work with the Schumacher wide stagger ribs, if not what wheels work?
Old 07-17-2016, 07:00 PM   #1844
Gayosaka's Avatar
The wide staggers fits all current front 4wd wheels, including Kyoshos.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 07-17-2016, 09:04 PM   #1845
