    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 05-02-2016, 11:04 AM   #1801
chriso138's Avatar
Default Hd chassis
Is anyone running the hd chassis? I'm wondering what effect it has on the car, and is it worth the coin? I'm running on med-high bite clay and turf.thanks
chriso138 is offline   Reply With Quote
Old 05-02-2016, 11:15 AM   #1802
chriso138's Avatar
Default Cvd /Cva pins
Can anyone tell me what size pins I need to replace the one's in the center drive shafts and axels? I ordered the mugen pin replacement tool but am having a hard time finding the right pins. Is there another company that makes them? Thanks
Old 05-02-2016, 11:23 AM   #1803
chriso138's Avatar
Default Front universal joint pins
The pins the hold my front cvd's/ universals together keep trying to work their way out. Does this happen to anyone else? If so ,what is the fix? If not, what can I do to help this problem? Thanks
Old 05-02-2016, 12:24 PM   #1804
I was hoping someone on here has made t he center diff like these pics i posted and was willing to sell one for a good amount of money. I do not have he tools needed to make it but am willing to pay to have it made as i really need it for the tracks ill be running on this series during the summer months. here are the pics i have seen.
to bad kyosho hasnt done what they said and released one by March now that we are in May and there is still no date still. #thanksalotkyosho
Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread-13083327_1292245957456200_2154896751463826960_n.jpg   Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread-13112529_10154329853364767_562556786_o.jpg   Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread-13115442_10154329853764767_1370024060_n.jpg
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 05-02-2016, 01:02 PM   #1805
I've used Traxxas pins. Part# TRA2754 and a little permanent locktite. Been running them for years in my swing shafts and 6 months in my center shafts.
Jeremy Clark
RB6 for Mid, ZX6 and an untold number of Axial crawlers for family fun...
Arcain41 is offline   Reply With Quote
Old 05-04-2016, 10:28 PM   #1806
likea45's Avatar
Looking for a good outdoor setup for this car. Track is loose and dusty clay. Usual tires are holeshots if that helps. All of the setups on petit for "low traction" dirt are all still running chain links or electrons and lead me to believe it's not compatible.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 05-06-2016, 09:09 PM   #1807
303slowdown's Avatar
Trader Rating: 21 (100%+)
This is the setup I've ran on low traction and it worked great. I ran it with blockades, Holeshots, and the Bowfighter combo and worked well with all of them. I ran my diffs medium tight though.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 05-06-2016, 11:05 PM   #1808
likea45's Avatar
Attachment 1364040
Interesting. This setup initially was intended for slicks. I'll give it a whirl.
Thanks.
Old 05-06-2016, 11:15 PM   #1809
JsK
JsK's Avatar
This one works well, 1/2 mm more shim at the back holder and a longer wheelbase if
its really slick. I also liked a little looser front diff vs the rear.
JsK is offline   Reply With Quote
Old 05-20-2016, 06:27 AM   #1810
What's the best tire to run on carpet?
gearit is offline   Reply With Quote
Old 05-20-2016, 08:12 AM   #1811
JsK
JsK's Avatar
For the rear its almost always Shumacher yellow mini pins. For the front I have
heard of everthing from the normal wide cut stagger, mini pins with rows trimmed
off to the narrow Lp stagger rib mounted on a cut down 4wd offset front wheel.
All Schumacher and almost always in yellow coumpound.
Old 05-20-2016, 09:21 AM   #1812
thanks
Old 05-22-2016, 07:09 AM   #1813
Tpg racer's Avatar
Hi all, i just got myself a used ZX6 for cheap but it needs quite a bit of refurbishment.
Does anyone know if its possible to replace the driveshaft pins on the ZX6 or are you required to buy a completely brand new driveshaft set?
I roughly know how to remove the pins but does Kyosho even sell the driveshaft pins separately?
I see Hudy sells 3mm pins for the XB4 but i am not sure about Kyosho.
Tpg racer is offline   Reply With Quote
Old 05-23-2016, 07:10 AM   #1814
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Kyosho does not sell the pins on their own. Your only option from Kyosho, that I know of, is to replace the bones themselves.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-23-2016, 10:49 AM   #1815
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
You can replace them,
I think you need either a 2mm or a 2.5mm pin, I've used some Taxxas pins in the past for the CVD dog bone pins and I think the center drive shaft pins are the same size, don't remember the Traxxas part number though. Make sure if you do replace them, you also use a little bit of red loctite one there too so the pin won't come out.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
