    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree9Likes
Old 02-05-2016, 07:23 AM   #1741
Drew Manzella's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Drew Manzella View Post
I did however order a pair of these:
http://www3.towerhobbies.com/cgi-bin...?&I=LXCBYH&P=7
At $1.99 each why not?
The front bar required a slight bend inward on each end. The rear works out of the package on the 713B arms BUT it is a little too narrow for the bulkhead so it doesn't float freely.
SpeedMerchant Rev.8 Pro Team Tamale LCG | | SpeedMerchant Rev.8 Pro | Kyosho Plazma RA | | Kyosho ZX6.5 | Kyosho ZX5 FS2 SP | Kyosho RB6.5 | Kyosho MP9 TKI3 | Custom Works Enforcer G6 | B4.1 SS
Drew Manzella is offline   Reply With Quote
Old 02-26-2016, 06:53 PM   #1742
is this trend died. with the new floating servo mount and aluminum chassis brace out. also the center diff should be up for pre order any day now if its middle to late march release time frame.
I was just looking for some HD chassis info. how is everyone running there's and what diff oils are people using. I see tebo is using heeavy in the rear then the front which is backwards. i was running why
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 02-28-2016, 02:56 PM   #1743
Originally Posted by randy0025 View Post
is this trend died.
What trend?
Theirs - not "there's".
I am running mine with the center section in the forward position and everything else is the same orientation as I had it on the old chassis.
10K front, 7K rear - but my car is set up for high traction carpet. I wouldn't run oil that heavy on dirt.
You were running what?
Old 02-28-2016, 06:19 PM   #1744
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
We are patiently waiting.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-28-2016, 08:50 PM   #1745
Johnn27's Avatar
Trader Rating: 72 (100%+)
Questions?? Center diff
When running the center diff can you still run balls front and rear or is it better to go gear diff all around?
Johnn27 is offline   Reply With Quote
Old 02-29-2016, 05:47 AM   #1746
None of us have ever run a center diff in a ZX6 - and since it isn't listed in the "new for March" parts we won't be running one til at least May (since the parts are never available in the month they say they will be).
I can't really think of a reason why you couldn't however.
Old 02-29-2016, 08:51 AM   #1747
Johnn27's Avatar
Smile
Yes, my question is theoretically, if I do get the center diff will i need the gear diffs or should I just leave it alone and run it the way it is if i do get it when it comes out.
Old 02-29-2016, 11:21 AM   #1748
Super Moderator
Kraig's Avatar
I haven't seen to many setup sheets that say gear diff here and ball diff their or vice versa. It is my opinion, and mine alone, that you should go all gear for the differentials including the center. But feel free to experiment because you might stumble on to something.
Old 03-02-2016, 07:58 PM   #1749
Can anyone tell me if there's an aftermarket aluminum steering solution yet?
http://www.infernosonly.com/Kyosho_L...p/kyola361.htm
Proudly sponsored by:
Pinnacle Hobbies
GLORCS RESULTS:2006: Buggy 20th, Truggy 12th 2007: Buggy 44th 2008: Buggy 10th 2009: Buggy 8th 2010: Buggy 10th, E-Buggy 2nd 2011: Buggy 9th, E-Buggy 7th
Gump is offline   Reply With Quote
Old 03-03-2016, 11:01 AM   #1750
I have mine setup with 5k front and 3k rear. as for the center diff I just got a pm from Joe and he said they are still expecting a release date of mid-end of March. Hopefully its not to far off that.
Old 03-03-2016, 11:13 AM   #1751
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
I have tried a couple of different combinations I started out with 5k front and 3k rear. It was pretty good. Then I went to 7k front and 3k in the rear and with that you kind of had to stay in the throttle to keep the rear from snapping lose. I drove my friends and it had 5K front and 7K in the rear. That was just ok. So now I am trying 5K front and rear for my big race next weekend.
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Old 03-03-2016, 11:16 AM   #1752
where are you running those oils at. Clubhouse, Dirt Burners, or AMS
I myself will be testing 5k, 5k this weekend
Old 03-03-2016, 11:39 AM   #1753
I run those at my home track. Rc Clubhouse. I am like 5 min from there. Traction is stupid in the beginning and kind of tapers off by the end of the night. its kind of weird.
Old 03-04-2016, 10:22 AM   #1754
tobamiester's Avatar
Trader Rating: 281 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Anyone know the part# for the cross pins (that go thru the small gears) in the gear diffs ? thx
tobamiester is offline   Reply With Quote
Old 03-04-2016, 10:34 AM   #1755
Here are the Shaft options:
http://www.amainhobbies.com/rc-cars-...oum613/p166194
http://www.amainhobbies.com/rc-cars-...tfw008/p274073
