    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 01-19-2016, 05:24 PM   #1696
Trader Rating: 131 (100%+)
Originally Posted by Teufel Racing View Post
You can, but it's not mandatory,
Use the ZX5/6 sway bar,
Swap the lower sway bar mount ballcup, to the med length shock rod end, put in the stock plastic ball in the shock rod end, then mount he lower sway bar mount inside the arm and run a screw through the sway bar mount hole in the arm to catch the new sway bar end inside the arm. It'll float just a tick, if you really want to, you can shim the lower sway bar mount in the arm tighter a couple ways.
It's super easy to do and it saves the cost of a whole sway bar kit you'll likely not need, u less you want it for the 2wd. If I remember correctly the RB6 sway bars are just a bit narrower than the ZX5/6 ones.
In the pic, I used a couple RB6 shock mounts trimmed and keyed to the arm to keep the lower mount from floating some, but it's not crucial to do.
thanks dude. is their any benefit in the HD chassis conversion set?
skyline1015 is offline   Reply With Quote
Old 01-19-2016, 05:29 PM   #1697
Drew Manzella's Avatar
Trader Rating: 27 (100%+)
Several:
  • Motor can be mounted farther forward
  • Battery can be mounted farther forward
  • Chassis is stiffer
  • Holes for LAW56 floating servo mount
  • Ready for the forth-coming center diff (may work in the old chassis however)
SpeedMerchant Rev.8 Pro Team Tamale LCG | | SpeedMerchant Rev.8 Pro | Kyosho Plazma RA | | Kyosho ZX6.5 | Kyosho ZX5 FS2 SP | Kyosho RB6.5 | Kyosho MP9 TKI3 | Custom Works Enforcer G6 | B4.1 SS
Drew Manzella is offline   Reply With Quote
Old 01-19-2016, 06:15 PM   #1698
Teufel Racing's Avatar
You're welcome,
Figured if ya could save some coin on the sway bar setup for the rb6 arms, y could spend more on other stuff. Lol.
As posted above,
Yes there are some benefits to the HD chassis,
I don't have one yet, but know a few racers that do have it on their car already,
Mainly a slightly longer overall wheel base is now doable, the ability to move the center slipper/motor forward and changing the weight bias, stiffer/less flex, and most notably for the yet to be released center diff option. Which I suspect is one of the main things it was designed for.
Sadly the center diff won't fit on the old chassis as the motor mount and slipper mount are too close, but if you took the time to drill the new holes in the chassis. You could,probably get it to work.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 01-19-2016, 06:39 PM   #1699
Here's the thing - in looking at the pics of the cars from Yatabe (who were all using the center diff) they are all using the same holes in the chassis for the motor mount/center bearing plate as I am using for my slipper.
I can't see how the center diff would be the same size as a slipper but the pics are pretty clear...
Old 01-19-2016, 08:45 PM   #1700
Holmberg418's Avatar
You're welcome,
As posted above,
The hd chassis is not longer then the stock chassis.
Kyosho America, Hobbywing, Jconcepts, Lunsford, JTP
Full Throttle R/C Raceway www.ftrcr.com
Holmberg418 is offline   Reply With Quote
Old 01-19-2016, 09:44 PM   #1701
If that were the case,
Kyosho would have the smallest center gear diff on the planet,
To the point onroad TC guys would be envious, and I wouldn't bet on that.
But hey, once the parts are out, then I guess the world will know for sure.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 01-20-2016, 04:52 AM   #1702
I'm not arguing. I'm just saying that in the Worlds pics they are using the same footprint our slippers do. Now maybe they didn't have the center diffs in for the photos...
Old 01-20-2016, 05:33 AM   #1703
Trader Rating: 48 (100%+)
Have to agree with this comment, one of the benefits of the he chassis is the ability to spread the area to accommodate the center gear diff. Tebo ran the gear diff at the jc Nats and u can't get a pic anywhere.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-20-2016, 06:43 AM   #1704
An employee at Kyosho America told me they were very proud to design the center diff to fit in the same spot as the slipper. He was also rather irritated he didn't have these parts to sell.
scoobyrs25 is offline   Reply With Quote
Old 01-20-2016, 11:54 AM   #1705
It's all good,
I know I've seen some setup sheets that do say a center diff was used, but as of yet, I don't think there have been pics out yet either, of course if they did figure out a way to stuff a center diff in the same spot as the slipper would normally be, which is entirely possible, then a pic or two may already be out and most not know it. Lol.
Hopefully the parts get released sooner than later, if for nothing else to have yet another tuning option.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 01-22-2016, 08:08 AM   #1706
for you guys that used the UM713B rear arms, are you guys using a set screw in the rear hub to keep the shaft from moving around? If anyone has a setup using these arms, I would appreciate a PIC if possible.
Old 01-22-2016, 11:30 AM   #1707
I use the Ultima outer hinge pin/nuts. In my opinion the ZX6 hinge pins aren't long enough (27mm vs the RB6 39mm).
http://www.amainhobbies.com/rc-cars-...oum561/p150085
Old 01-22-2016, 11:41 AM   #1708
thank you sir.
Old 01-25-2016, 07:36 PM   #1709
so I was looking for the new HD Chassis since I will be buying the center diff when it does come out. the only thing is i see 2 hd chassis's. one part number is KYOLAW54B and the other is KYOLAW54. the KYOLAW54 says something about being ale to move the motor mount and add the center diff so if thats the case then whats the difference of the two
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 01-25-2016, 08:11 PM   #1710
Johnn27's Avatar
Trader Rating: 71 (100%+)
Thumbs up LAW54 v. Law54b
The law54, which I converted my car to, allows you to move the motor and battery forward 8mm. It is also heavier and stiffer than the original chassis.
The LAW54b is the chassis which in edition to all that also allows you to use the floating servo mount. I believe they will discontinue the law54 and just offer the law54b.
Johnn27 is offline   Reply With Quote
