    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 01-10-2016, 01:53 PM   #1681
303slowdown's Avatar
Trader Rating: 24 (100%+)
Well yesterday was the first time running the zx6 I bought off eBay and it wasn't to bad. Does anyone make a way to put the rear shocks on the back of the arms. The track I run at is very low traction and I think I could benefit from moving the shocks to the rear. Thanks
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 01-10-2016, 02:37 PM   #1682
Tony Marks's Avatar
Anyone played around with floating servo mounts? Finding anything that fits?
Team Kyosho America - VP Powermaster
JConcepts - 92zero Designs
Full Throttle/510 Raceway
Jared Tebo Products
Tony Marks is offline   Reply With Quote
Old 01-12-2016, 06:47 AM   #1683
Drew Manzella's Avatar
Trader Rating: 27 (100%+)
I haven't looked but here is what I can tell you from examining my LAW54B chassis closer - The Kyosho LAW56 is scalloped to fit around the front brace:
This is going to make it difficult to impossible to install pretty much any other part (even if bolt patterns are the same).
You could get creative and shift it forward but then other problems will arise...
SpeedMerchant Rev.8 Pro Team Tamale LCG | | SpeedMerchant Rev.8 Pro | Kyosho Plazma RA | | Kyosho ZX6.5 | Kyosho ZX5 FS2 SP | Kyosho RB6.5 | Kyosho MP9 TKI3 | Custom Works Enforcer G6 | B4.1 SS
Drew Manzella is offline   Reply With Quote
Old 01-14-2016, 10:04 AM   #1684
mmobee1's Avatar
Smile Kyosho ZX6 - on Carpet
Hi Guys,
Looking for set-ups for the ZX6 on carpet. I've seen the 2015 worlds & Tebo's set-ups and Astro. set ups too, but any advice or pitfalls to avoid, would be much appreciated
If it ain't broke, don't fix it........
mmobee1 is offline   Reply With Quote
Old 01-14-2016, 01:11 PM   #1685
Over-rev's Avatar
Interested in this as well. Is it better to run with slick rubber or foam on a ZX6 for carpet?
And behold, a pale horse, and he who sat upon it, his name was death, and Hades followed him - Revelation 6:8
ΜΟΛΩΝ ΛΑΒΕ
Over-rev is offline   Reply With Quote
Old 01-14-2016, 04:35 PM   #1686
Mark506's Avatar
Trader Rating: 41 (100%+)
I'm sure it's been covered in this thread, but I recently picked up a secondhand zx6 and it came with 5-hole pistons.
Whats all the hype around the 2 hole piston? Yes, I understand the the fluid mechanics behind it, but never knew why Kyosho guys preferred the two hole route.
Thanks!
Mark Ament
l MOMO USA l OZ Racing l Willwood Brakes | Dunlop Tires |
The Raceway at Beaver: Forever In Blue Jeans
Mark506 is offline   Reply With Quote
Old 01-15-2016, 04:29 AM   #1687
You guys will get more answers if you post this in the Electric Offroad Forum (Or the ZX6 thread in that forum). Offroad is offroad regardless of the surface...
I run Pro-Line Pinpoints (F/R) and/or Schumacher Stagger Rib 2.2 fronts / Mini Pin 2 rears on my ZX6.
The key to a good carpet setup is mitigating traction rolling. Unfortunately the track layout and carpet type (both vary from track to track) dictate side loads so it is tough to take a setup and say "this will work for you".
A lot of people like the Roger Mills "Astroturf Base Setup with Shortie" setup on PetitRC as a starting point. Work from there.
My ZX6 set up for carpet:
Old 01-15-2016, 11:32 PM   #1688
Super Moderator
Grizzbob's Avatar
Actually, best thing to do is merge this with the existing ZX6 thread, & that's what I'm doing now....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 01-16-2016, 09:48 AM   #1689
Trader Rating: 20 (100%+)
Thumbs up
hi all i want to rebuild the diffs in the car does anyone know the quickest most efficient way of getting the diffs out the car thank you in advance!
toyota 2jz is offline   Reply With Quote
Old 01-19-2016, 02:58 AM   #1690
eper's Avatar
Trader Rating: 14 (100%+)
iknow the rear diff is like 8 screws and out. id imagine the front is just as easy. pop the shocks off at 1 end and the camberlink ff at 1 end and the tower and gearbox cap pop off in one piece
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 01-19-2016, 10:22 AM   #1691
Trader Rating: 131 (100%+)
Default option part UM713B
Hey guys, new to the zx6 platform. Do I need to use the sway bar kit for the rb6 when I use the option rear arms?
skyline1015 is offline   Reply With Quote
Old 01-19-2016, 11:14 AM   #1692
Trader Rating: 49 (100%+)
Yes unhave to use the rb6 sway bar kit Enzo. Getting the zx6 again?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-19-2016, 11:21 AM   #1693
thanks chris. do i need the sway bar for RM or MM RB6? i still have the d413. no sense of getting rid of it considering i have enough parts to build another buggy. I wanted to give the zx6 another try. maybe run a 13.5 during the summer at Cruizin
Old 01-19-2016, 12:50 PM   #1694
Just get them mm kit bc it will come with all the necessary stuff to fit it on the rb6 arms
My Credit Card
Old 01-19-2016, 04:35 PM   #1695
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
You can, but it's not mandatory,
Use the ZX5/6 sway bar,
Swap the lower sway bar mount ballcup, to the med length shock rod end, put in the stock plastic ball in the shock rod end, then mount he lower sway bar mount inside the arm and run a screw through the sway bar mount hole in the arm to catch the new sway bar end inside the arm. It'll float just a tick, if you really want to, you can shim the lower sway bar mount in the arm tighter a couple ways.
It's super easy to do and it saves the cost of a whole sway bar kit you'll likely not need, u less you want it for the 2wd. If I remember correctly the RB6 sway bars are just a bit narrower than the ZX5/6 ones.
In the pic, I used a couple RB6 shock mounts trimmed and keyed to the arm to keep the lower mount from floating some, but it's not crucial to do.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
