    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 10-27-2015, 03:18 PM   #1606
Regional Moderator
RobsRacin's Avatar
Originally Posted by jpcopeland1 View Post
Its gonna be uber expensive for the competition kit, (possibly more then the ZX-6) and the ZX-6 is a proven platform where I race.
Oh I understand, hope you dont want all those spares back I bought from you
RobsRacin is offline   Reply With Quote
Old 10-28-2015, 09:55 AM   #1607
Trader Rating: 137 (100%+)
No, not at all lol.... I have new spares.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 11-01-2015, 09:27 AM   #1608
Trader Rating: 37 (100%+)
Default Pin
Anyone run the pin in the slipper assembly?
Why would connecting the front and rear help? I mainly run indoor clay 13.5T.
Nexus is offline   Reply With Quote
Old 11-01-2015, 10:17 PM   #1609
I did by mistake, and the car was undrivable. All the team guys I talked to about it said they never run it. Took it out, and car was awesome.
Old 11-02-2015, 12:07 PM   #1610
Excellent and thanks.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Old 11-13-2015, 05:50 AM   #1611
Can you buy the cross pins (the planetary gears ride on) for the gear diffs separately? I can't even find a part number for them.
potatobed409 is offline   Reply With Quote
Old 11-16-2015, 05:54 AM   #1612
rpboggs1's Avatar
Trader Rating: 19 (100%+)
How is everyone's turning radius? Mine sees to be excessively wide but I can't figure out how to fix it... The inner tire has a good steering angle but the outer tire only turns slightly. The car is awesome everywhere except for the 2 or 3 low speed hairpin turns.
Kyosho RB6 * Kyosho ZX6 * Kyosho RT6
TLR 22SCT * TLR SCTE 2.0
Tekno NB48.3 * Tekno EB48.4 * Tekno EB48.3 * Tekno ET48.3
rpboggs1 is offline   Reply With Quote
Old 11-16-2015, 06:25 AM   #1613
Regional Moderator
RobsRacin's Avatar
Is the steering block arm hitting the a-arm at all? I know if you put the steering blocks on upside down they will hit the arms and not turn fully.
My car seems to be fine in the slow stuff, no issues with turning
Old 11-17-2015, 06:00 AM   #1614
rpboggs1's Avatar
Thanks for the response! It looks like steering block arm is just missing the a arm. The c-hub is positioned with the steering arm on the top half. Hopefully that is the right way.
Old 11-17-2015, 06:04 AM   #1615
Regional Moderator
RobsRacin's Avatar
Yes that is the correct way, if the steering arm clears the arm at full droop you know it is on correctly. How tight are your diffs?
Old 11-17-2015, 06:11 AM   #1616
rpboggs1's Avatar
Old 11-17-2015, 06:13 AM   #1617
rpboggs1's Avatar
Just uploaded a picture at full lock. The front diff is tight and the rear is medium.
Old 11-17-2015, 06:17 AM   #1618
Regional Moderator
RobsRacin's Avatar
Hmmm I will compare with mine this evening when I get home from work
Old 11-17-2015, 06:33 AM   #1619
rpboggs1's Avatar
Awesome! Thank you very much!
Old 11-18-2015, 05:40 AM   #1620
eper's Avatar
Trader Rating: 14 (100%+)
u should run the front diff a little more loose then the rear. makes the car enter harder. can u post entire setup or are u running one from petit rc that u can tell me which one
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
