    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 10-16-2015, 05:04 PM   #1591
Regional Moderator
RobsRacin's Avatar
Originally Posted by raved007 View Post
Any info if they make center differential of this buggy?
Not yet they dont
RobsRacin is offline   Reply With Quote
Old 10-16-2015, 09:55 PM   #1592
They were using center diffs in the worlds so they should be comercially available sometime this year
nitroargi is offline   Reply With Quote
Old 10-20-2015, 08:00 PM   #1593
stinky cheese's Avatar
Trader Rating: 21 (100%+)
Default BALL STUD
Hi all,
Can someone tell me which ball stud to use when putting 4mm of shims under the outer steering ball stud. I noticed a few people have been running this lately. Also how does this change the handling? Thanks in advance.
Cheese
My racing is supported by the following companies
AKA Tires. http://www.ryperhobbies.com.au/
TKO Competition Development. http://premiermodelsupplies.com/
Tornado RC Chargers
Schelle Racing Innovations.
stinky cheese is offline   Reply With Quote
Old 10-21-2015, 12:13 AM   #1594
Stevomatik's Avatar
Originally Posted by Nexus View Post
Is the JConcepts Silencer the only other body avaliable? The Kyosho body is nice looking, but just checking if anything else was released.
IMO the JC body is ugly as hell.
I bought the jc body and ran it... In my opinion didn't have as much rotation in the turns as the stock body
Stevomatik is offline   Reply With Quote
Old 10-21-2015, 10:01 AM   #1595
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by stinky cheese View Post
Hi all,
Cheese
I think you will want part number um128.
It changes the bump steer characteristics as the arm moves up and down. I haven't tested this option back to back so I can't tell you what I felt on the track when I did this.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-21-2015, 10:07 AM   #1596
Trader Rating: 137 (100%+)
You are correct sir.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-21-2015, 10:31 AM   #1597
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
With 10 degree caster it drops the stud on the steering arm so to get 0 bump you just raise it back up. If you run less than 4mm you will get more bump in which can make the front end do weird things.
K_King is offline   Reply With Quote
Old 10-21-2015, 12:54 PM   #1598
Thanks Kraig,JP and Kevin for the info.
Tornado RC Chargers
Old 10-25-2015, 09:10 PM   #1599
Johnn27's Avatar
Default New Chassis
I am converting my ZX6 to the new chassis and I was wondering where I should place the battery I currently have it set up with the motor on the driver side facing forward and the battery on the left I was thinking of moving the shorty pack forward for better balance. Where are most people running the shorty? Also anybody have a new trick on mounting the sway bar on the rb6 arm? . Lastly which hole on the RB6 arm should I mount the shocks? the inner of the three outer holes I assume ??? Any tips, tricks info is appreciated Thx!
Johnn27 is offline   Reply With Quote
Old 10-26-2015, 08:26 AM   #1600
cclifton's Avatar
Send a message via MSN to cclifton
Anyone running the ZX6 in 13.5? I was just wondering on a starting point for gearing.
The Fleet:Xray:XT2 - Associated B6, B64
For Sale :Xray XB2 CE 2016 w/XB2 DE conversion
Poorboy Raceway and Hobbies
Grants Pass, OR
cclifton is offline   Reply With Quote
Old 10-26-2015, 08:57 AM   #1601
As far as the shocks go I tend to run the middle hole the most.
Old 10-26-2015, 09:08 AM   #1602
So does building your car with the caster blocks wrong... damn failing eyes!
Old 10-26-2015, 09:09 AM   #1603
Trader Rating: 37 (100%+)
I've run everything from a 23T to 26T using Speed Passion V3 and now V4 13.5s
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 10-26-2015, 07:25 PM   #1604
Regional Moderator
RobsRacin's Avatar
Ah you went back to a ZX6? I thought you were thinking of waiting for the YZ4? Any reason why you decided not to?
Old 10-27-2015, 12:52 PM   #1605
Its gonna be uber expensive for the competition kit, (possibly more then the ZX-6) and the ZX-6 is a proven platform where I race.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
masterhit
