    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 09-10-2015, 10:18 AM   #1561
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Originally Posted by cnelson3 View Post
I misunderstood. A lot of my steering issues went away when I went motor forward. Diff could be too tight. You could also try going narrower on the front hinge pin blocks. something else that worked for me was moving the shock in on the rear tower. Do you have a base setup you are working off?
Is your rear end planted?
K_King is offline   Reply With Quote
Old 09-10-2015, 10:34 AM   #1562
cnelson3's Avatar
Trader Rating: 65 (100%+)
For the most part, yeah. I think the rear kick up is the reason though. I run the 4 bump spacer under the FR toe block and the 2 bump spacer under the RR block. I saw it on someone's setup and just tried it and really liked it. It keeps the back end from snapping out and I can drive the car hard without feeling like the car is going to loop out.
cnelson3 is offline   Reply With Quote
Old 09-10-2015, 10:44 AM   #1563
K_King's Avatar
Damn that's a lot lol. Isn't that the same as running 0/2?
Old 09-10-2015, 11:41 AM   #1564
cnelson3's Avatar
Originally Posted by RobsRacin View Post
Yes I should of thought about the diffs while I was at the track but I would say about 3/4 rotation in the front and just over a full turn in the rear as far as diff tightness. Im working off this set currently...
http://www.petitrc.com/setup/kyosho/...i_RCE20150312/
I would do a few things differently but they would be for my track and my driving style. Red front springs, move the hubs back 1 or 2 mm's. I liked the yellow fronts too but the Reds were similar feeing but added a little more steering. The only other thing may be to narrow up the front track width and go with c in/c in. You'll have to test these out a bit to see what you like but this is where I would start.
Old 09-10-2015, 11:43 AM   #1565
Regional Moderator
RobsRacin's Avatar
Great I appreciate the input!
RobsRacin is offline   Reply With Quote
Old 09-10-2015, 11:50 AM   #1566
cnelson3's Avatar
Yeah I know but whatever the reason, it felt good. i saw it that way on someone else's setup sheet. Had similar issues with the back being "snappy" and it helped.
I would assume it is the same as 2 bump in the RR only. Try it out and let us know. I never messed with it after I was happy.
Old 09-10-2015, 02:07 PM   #1567
K_King's Avatar
I'll try it. I think I do like the higher rear pivot like in 2w.
Old 09-10-2015, 04:04 PM   #1568
tef
Elliot Boots runs that setup with the 4/2. He also makes comments about having to shave some parts. I think its on petitrc if you wantnto look at his comments.
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 09-10-2015, 04:10 PM   #1569
tef
This is my setup, when they change the layout at RC Excitement it really helps the car turn and be free. Its really twitchy as traction comes up.
I have my cars set for turf for this weekends turf nationals and will be posting those setups too if they are any good. If you go the race this weekend at RC Madness swing by and say hi.
My RB6 was really good the one time i drove it on turf if you have that car and looking for a setup for that too on turf.
Old 09-10-2015, 06:02 PM   #1570
Regional Moderator
RobsRacin's Avatar
I will try and swing by sunday for the mains after work, post up here where you are pitting ill come say hi. Hopefully you guys have good weather. You will love the turf, I fell in love with it but its over an hour away with no traffic so I cant club race with work going on
Old 09-14-2015, 10:43 AM   #1571
Fresh shell and wing on my ZX-6
Headling is offline   Reply With Quote
Old 09-15-2015, 02:32 AM   #1572
tef
Looking good!
Old 09-15-2015, 06:20 AM   #1573
Thanks, yes really pleased with the new paint job
Old 09-15-2015, 05:54 PM   #1574
jag5508's Avatar
Trader Rating: 14 (100%+)
What are you running for a setup at RC Excitement ? I going to try and get down there real soon .
TOYZ 4 BOYZ
jag5508 is offline   Reply With Quote
Old 09-16-2015, 07:52 AM   #1575
tef
I'm heading to RC Excitement within the next week or so and I'm changing my 4wd completely. I'll post my setup after I run.
